Dynamically creating compositeSymbol with pictureMarker and textMarker symbols
6030
11
12-27-2018 10:01 AM
TerryCoe
I am trying to create Composite Symbols that contain both a Picture Marker Symbol and a Text Symbol.
for some reason, the picture Marker Symbol is not consistently created in the composite symbol. So I am hoping that someone here can see what has been done wrong and help me out. Using C#, here is my code:
private async void SetMapSymbols()
var previousLayer = GraphicsLayer[SEARCH_LAYER];
GraphicsLayer.Remove(previousLayer);
var graphicsOverlay = new GraphicsOverlay() { Id = SEARCH_LAYER };
var graphicList = new List<Graphic>();
int order = 0;
foreach (RequestInfoModel entry in PermitList)
order++;
if (entry.SiteGeoLat == null || entry.SiteGeoLong == null) continue;
var pointAttribList = ConvertObjectToDictionary(entry);
DictionaryUtility.AddItemTodictionaryAttribute(pointAttribList, ORDER_ATTRIBUTE, order.ToString());
var geo = entry.AltSiteGeoLat != null && entry.AltSiteGeoLong != null ? WebMercatorUtility.ConvertToMercator(entry.AltSiteGeoLong.Value, entry.AltSiteGeoLat.Value) : WebMercatorUtility.ConvertToMercator(entry.SiteGeoLong.Value, entry.SiteGeoLat.Value);
var graphic = new Graphic(
new MapPoint(geo.Lon, geo.Lat, new SpatialReference(SPATIAL_REFERENCE)),
pointAttribList,
string.IsNullOrEmpty(entry.InspectorArea) ? await SymbolUtility.CreateSymbols(order.ToString(), SymbolTypes.Blue, SymbolShapes.Pin) :
await SymbolUtility.CreateSymbols(order.ToString(), SymbolTypes.Red, SymbolShapes.Arrow));
if (entry.SiteGeoTypeCode != MAPPABLE)
graphic.Symbol = string.IsNullOrEmpty(entry.InspectorArea) ? await SymbolUtility.CreateSymbols(order.ToString(), SymbolTypes.Blue, SymbolShapes.Pin2) :
await SymbolUtility.CreateSymbols(order.ToString(), SymbolTypes.Red, SymbolShapes.Arrow2);
graphicList.Add(graphic);
graphicList.ForEach(x => graphicsOverlay.Graphics.Add(x));
GraphicsLayer.Add(graphicsOverlay);
as you can see, i am awaiting the SymbolUtility, so here is that code:
public static async Task<Symbol> CreateSymbols(string text, SymbolTypes type, SymbolShapes shape)
var iconPath = string.Empty;
iconPath = string.Format(@"pack://application:,,,/Images/{0}_{1}.png", type.ToString(), shape.ToString());
var pc = new PictureMarkerSymbol(new Uri(iconPath, UriKind.RelativeOrAbsolute));
pc.Width = 30;
pc.Height = 30;
var cm = new CompositeSymbol();
var ts = new TextSymbol()
Color = Colors.Black,
FontStyle = FontStyle.Normal,
FontDecoration = FontDecoration.None,
FontFamily = "Arial",
FontWeight = FontWeight.Bold,
Size = 14,
VerticalAlignment = VerticalAlignment.Middle,
HorizontalAlignment = HorizontalAlignment.Center,
OffsetY = shape == SymbolShapes.Arrow ? 5 : 0
ts.Text = text;
cm.Symbols.Add(pc);
cm.Symbols.Add(ts);
return await Task.Factory.StartNew<Symbol>(() => { return pc; });
here is a screen grab of 1 symbol that generated properly, and 2 that didn't:
picture of 1 icon rendering properly and two that do not
I have created a thread on StackOverflow here, but a person there directed me here to ask. Thank you for reading this far. any help would be greatly appreciated.
UPDATE:
Here is the additional info requested below:
picture symbol for testing
the graphic.Geometry :
{"x":-13703208.904060207,"y":5882055.3633824475,"spatialReference":{"wkid":102100,"latestWkid":3857}}
the Spatial Reference = 3857
TerryCoe
I will try that first thing tomorrow, since I reverted back to 4.6.0 today already.
TerryCoe
Completing this is not an option for me, due to time constraints and the regression testing needed to ensure it was done properly.
Quick Question though:
What type of files could be used as a PictureMarkerSymbol? I am thinking that the .PNG files might not scale well to a vector tile base map, and the visible extent, so I was going to try converting to a .SVG file. But thats a lot of work, so I want to be sure the object can render it properly.
