CreateDynamicLayerInfosFromLayerInfos() does not work with a .MPK that references an SDE Database.
5282
01-05-2015 05:16 PM
TrevorHooper
It works if the .mpk is a does not reference the SDE but instead takes a copy of the layers. Another strange thing is that any Raster layers in the .MPK are not visible if the .mpk references the SDE DB but are if the .mpk is a copy. Does anyone have any ideas why this might be? And what I have to do when provisioning the .mpk that references the SDE DB so it works like the .mpk that takes a copy of the SDE layers.
I am using Runtime 10.24 For .Net
Trevor
MichaelBranscomb
Esri Frequent Contributor
Hi Trevor,
Please can you give some background on what you are trying to achieve and provide the code to reproduce the problem? (we can point at an SDE instance here)
Cheers
Mike
TrevorHooper
Hi Mike,
    Thanks for the quick reply.
I am programming a Runtime 10.24 .NET WPF application for a client. They have a large Oracle Geodatabase with a SDE front end. The application is using the LocalServer functionality to access the Geodatabase layers via a map Package. (They do not have the licencing required to publish a map service). As a proof of concept we have been using a small .mpk file so that I could program all of the functionality needed in the App without connecting to the SDE (I don't have permission). Everything works well with this .mpk
here is a link:   https://dl.dropboxusercontent.com/u/48200319/BDT_Test_AreaSmall.mpk
The problem has come up when we changed the MapPackage to one that References the SDE.
Link here: https://dl.dropboxusercontent.com/u/48200319/BDT_Test_AreaWithRasters.mpk
The problem occurs when using the BDT_Test_AreaWithRasters.mpk
problem 1: when I load the mpk with the code in the MyMapView_LayerLoaded handler commented out. All layers except for the 2 Raster layers show up in the Legend. (Of course no data is displayed as I don't have an SDE connection). So why don't the Raster layers show in the legend. If I leave the Rasters out of the MapPackage and have an SDE connection the data displays.
problem2: I want to re-order some layers and in a different place in the code be able to change renderers on "ITLBackgroundData"(0). To do this I need to get the DynamicLayerInfoCollection using
CreateDynamicLayerInfosFromLayerInfos(). This works fine when using BDT_Test_AreaSmall.mpk  but fails when using BDT_Test_AreaWithRasters.mpk
Any thoughts would be appreciated.
Cheers Trevor
Here is some code that should reproduce the problem:
Dim _localMapService As LocalMapService  'Global Variable
Private Async Sub LoadBackgrounds()
Try
Dim mySpatialReference As Esri.ArcGISRuntime.Geometry.SpatialReference
mySpatialReference = Esri.ArcGISRuntime.Geometry.SpatialReference.Create(3005)
MyMapView.Map.SpatialReference = mySpatialReference
Dim myEnvelope As Esri.ArcGISRuntime.Geometry.Envelope
myEnvelope = New Esri.ArcGISRuntime.Geometry.Envelope(1070635.92, 499061.341, 1071988.61, 499115.4)
MyMapView.Map.InitialViewpoint = New Esri.ArcGISRuntime.Controls.Viewpoint(myEnvelope)
_localMapService = New LocalMapService("..\..\MapData\BDTData\BDT_Test_Area.mpk", 1000000, True)
_localMapService.EnableDynamicLayers = True
Await _localMapService.StartAsync()
Dim arcGISDynamicMapServiceLayer As ArcGISDynamicMapServiceLayer
arcGISDynamicMapServiceLayer = New ArcGISDynamicMapServiceLayer()
arcGISDynamicMapServiceLayer.ID = "ITLBackgroundData"
arcGISDynamicMapServiceLayer.ServiceUri = _localMapService.UrlMapService
arcGISDynamicMapServiceLayer.IsVisible = True
MyMapView.Map.Layers.Add(arcGISDynamicMapServiceLayer)
Catch ex As System.Net.HttpListenerException
MessageBox.Show(ex.ToString)
End Try
End Sub
Private Sub MyMapView_LayerLoaded(sender As Object, e As LayerLoadedEventArgs) Handles MyMapView.LayerLoaded
If e.Layer.ID = "ITLBackgroundData" Then
If Not IsBusy Then
IsBusy = True
Dim myDynamicLayerInfos As DynamicLayerInfoCollection = (TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer)).DynamicLayerInfos
If myDynamicLayerInfos Is Nothing Then
myDynamicLayerInfos = (TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer)).CreateDynamicLayerInfosFromLayerInfos()
If Not myDynamicLayerInfos Is Nothing Then
MessageBox.Show("Layer infos OK")
Dim sourceArray(myDynamicLayerInfos.Count) As DynamicLayerInfo
myDynamicLayerInfos.CopyTo(sourceArray, 0)
TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos = myDynamicLayerInfos
TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.RemoveAt(0)
TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray(0))
TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.RemoveAt(1)
TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray(2))
TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray(1))
Else
MessageBox.Show("Layer infos Not OK")
End If
End If
End If
End If
End Sub
TrevorHooper
I have worked around this problem with the following code, If  CreateDynamicLayerInfosFromLayerInfos() fails, I Generate the DynamicLayerInfos one by one(This does not answer the question why the CreateDynamicLayerInfosFromLayerInfos() fails 😞
                        'MessageBox.Show("Layer infos OK")
                        TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray(3))
                    Else
                        myDynamicLayerInfos = New DynamicLayerInfoCollection
                        Dim lms As New LayerMapSource
                        lms.MapLayerID = 0
                        Dim dli As DynamicLayerInfo
                        Dim sourceArray2(19) As DynamicLayerInfo
                        Dim myLayerDataSource As Esri.ArcGISRuntime.Layers.LayerDataSource
                        For i = 0 To 19
                            dli = New DynamicLayerInfo
                            dli.Source = lms
                            dli.ID = i
                            myDynamicLayerInfos.Add(dli)
                        myDynamicLayerInfos.CopyTo(sourceArray2, 0)
                        TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray2(0))
                        TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray2(1))
                        TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray2(2))
                        TryCast(MyMap.Layers("ITLBackgroundData"), ArcGISDynamicMapServiceLayer).DynamicLayerInfos.Add(sourceArray2(3))
                        'MessageBox.Show("Layer infos Not OK")
                    End If
                End If
