Converting an Excel Spreadsheet/Access Table to a File Geodatabase.
4821
10-31-2014 07:39 PM
Dale_Shearer
Thanks for looking at my issue.  I want to convert an Excel Spreadsheet into a File Geodatabase.  This has to be done in VB.Net  code, yes the database conversion tool code is available, but it is in Python.  I thought I could find a simple routine/feature that would take care of it, I have went over ESRI's site and I have not found anything so far, that does not mean it is out there.
What I have done is convert the Excel file to an Access Table, then take that table and try to convert it into a File Geodatabase using the IFeatureDataConverter.  I can create the File Geodaabase and then get a dataset with the field names, but no data, so I am missing something, or not interpreting something correctly.
The base for my routine is the ConvertTable routine from this site, from what I have seen there are several samples out there built off the following code.
Sub ConvertTable()
'++ Convert an OLE DB table to a ArcSDE Geodatabase table
'++ Data source is an existing ODBC DSN connection to an MS Excel file
'++ OLE DB provider is MS OLE DB provider for ODBC Drivers
Dim InTable As String, OutTable As String
Dim ConStr As String, InProg_id As String, OutProg_id As String
ConStr = "Provider=MSDASQL.1;Data Source=Excel_wks"
'++ Set the In and Out WorkspaceFactory Prog_ids
InProg_id = "esriCore.OLEDBWorkspaceFactory.1"
OutProg_id = "esriCore.SDEWorkspaceFactory.1"
InTable = "codemog"
OutTable = "vtest.vtest.CODEMOG"
'++ Create the Source Workspace
Dim pWorkspaceIn As IWorkspaceName
Set pWorkspaceIn = New WorkspaceName
'++ Set the Source Workspace Properties
Dim pInPropset As IPropertySet
Set pInPropset = New PropertySet
pInPropset.SetProperty "CONNECTSTRING", ConStr
pWorkspaceIn.ConnectionProperties = pInPropset
pWorkspaceIn.WorkspaceFactoryProgID = InProg_id
'++ Assign input table name
Dim pInTableName As ITableName
Set pInTableName = New TableName
Dim pInDatasetName As IDatasetName
Set pInDatasetName = pInTableName
pInDatasetName.Name = InTable
Set pInDatasetName.WorkspaceName = pWorkspaceIn
'++ Create the Destination GDB workspace.
Dim pOutPropSet As IPropertySet
Set pOutPropSet = New PropertySet
Dim pWorkspaceOut As IWorkspaceName
Set pWorkspaceOut = New WorkspaceName
pWorkspaceOut.WorkspaceFactoryProgID = OutProg_id
With pOutPropSet
   .SetProperty "Server", "fabio"
   .SetProperty "Instance", "5152"
   .SetProperty "Database", "vtest"
   .SetProperty "user", "vtest"
   .SetProperty "password", "go"
   .SetProperty "version", "VTEST.EV1"
End With
pWorkspaceOut.ConnectionProperties = pOutPropSet
'++ Create the destination table object
Dim pOutDatasetName As IDatasetName
Dim pOutTableName As ITableName
Set pOutTableName = New TableName
Set pOutDatasetName = pOutTableName
Set pOutDatasetName.WorkspaceName = pWorkspaceOut
pOutDatasetName.Name = OutTable
'++ Open input table to get field definitions.
Dim pname As IName
Dim pTableIn As ITable
Set pname = pInTableName
Set pTableIn = pname.Open
'++ Validate the input table field names
Dim pInTableFields As IFields
Dim pOutTableFields As IFields
Dim pFieldCheck As IFieldChecker
Dim outEnumFieldError As esriCore.IEnumFieldError
Set pFieldCheck = New FieldChecker
Set pInTableFields = pTableIn.Fields
pFieldCheck.Validate pInTableFields, outEnumFieldError, pOutTableFields
'++ if there are no field errors reported, proceed to convert
If outEnumFieldError Is Nothing Then
   Dim pOleDBToGDB As IFeatureDataConverter
   Set pOleDBToGDB = New FeatureDataConverter
   pOleDBToGDB.ConvertTable pInDatasetName, Nothing, pOutDatasetName, pOutTableFields, "", 1000, 0
End If
End Sub
'++ To convert an OLE DB table to a Personal Geodatabase table
'++ Change the OutProg_id to "esriCore.AccessWorkspaceFactory.1"
'++ and set the destination workspace property "DATABASE" as follows
'++ pOutPropSet.SetProperty "DATABASE", "d:\data\us_states.mdb"
'++ You may also wish to change the destination table name
I have changed the code to where the input is an .mdb and the output is a FileGDBWorkspaceFactory, when it goes through the pOleDBToGDB.ConvertTable portion I get a dataset with the column names from the .mdb, but no data.
This could be an issue, there are 123,000 rows in the .mdb table, not sure if that is an issue or not.
I would post my code but it is Friday night at 9:30 pm and I am still running it through my mind.
So basically is there a routine out there that just does a simple input file-output file-convert.
If not, what am I missing by using this routine (with some modifications) to convert an .mdb to a File Geodatabase.  I am just putting the Geodatabase in a folder on my C: drive.
Thanks for taking a look, Dale,
