Change MapView Parent Quickly Cause Map Blank
5150
06-27-2018 12:28 AM
xiaoguangyan
I have a demo with to TabItem, switch TabItem change the MapView parent, if switching very quick the map will be disapear will be blank, the demo is attached, our project change the MapView like this demo have the same issue.
Tags (1)
JenniferNery
Thank you for providing us a repro sample. I was able to reproduce with v100.2.1, quickly switching tabs would sometimes not redraw the map. However this appears fixed with latest dev build for v100.3.
xiaoguangyan
May I ask that when the v100.3 will release?
