Authentication required for Geodatabase Sync
782
04-26-2022 09:48 AM
JohnFannon
Hi
I've tried to implement a download of a mobile geodatabase from an ArcGIS Online feature service followed by a sync based on the sample at https://developers.arcgis.com/net/uwp/sample-code/edit-and-sync-features/.
I have set the feature service as public (for testing) and the initial download using GenerateGeodatabase works ok, without any authentication. However, when I then try to perform a sync (download only) I'm getting prompted for ArcGIS credentials. If I enter credentials it just continues to prompt, then if I cancel I get an error as follows:
Esri.ArcGISRuntime.ArcGISServerException: 'Service error code 401: Unable to synchronize replica.
Details:
No permission to edit replica data : 96f78289-48df-4a19-9b4c-02352c905a44.'
So I have some questions:
1) Why does sync require credentials when download doesn't - even though the service is public?
2) The licensing documentation suggests both download and sync are available with a Lite license, which uses an API key. If the feature service was secured, what is the correct way to provide credentials if the app does not use a named user? Should we use application authentication?
Any thoughts appreciated.
John
