ArcGISDynamicMapServiceLayer not visible in Scene View
4155
07-27-2015 10:11 AM
JosephKane
Im trying to load a geotif to the new Scene View 3d map for .net desktop using the same workflow as with the 2d Map View.  When i do, there are no obvious errors but the geotif is not visible on the globe.  The work flow im using is the same as the sdk 10.2.5 examples.. Create local map service with the mpk (from the examples), create a ArcGISDynamicMapServiceLayer and add it to my Layers.
Any help would be greatly appreciated.
Joe
JosephKane
As it turns out the map pack in the 10.2.5 examples only has a boundary extent of the eastern U.S.  That means any data you try to view with it (in the scene view for some reason) is only visible on the east coast.  Once we created a map package with a boundary extent covering the entire world the geotif loaded correctly.
thanks for trying to help out..
FreddieGibson
Honored Contributor
Can you upload some of your data for testing?
JosephKane
