ArcGIS Runtime Licensing
8817
7
11-02-2018 01:38 AM
KhurramAli
I have been asking few questions regarding the ArcGIS Runtime Licensing from my local ArcGIS distributor but they haven't replied for many days and also I found this question  https://community.esri.com/thread/164451, now these questions are
  1. Is Developer required to purchase application Runtime License for every application distributed? For example, we develop an app and want to distribute it to 10 devices, do we need just one developer license and then we can distribute as many as we can? Or we need license for each device i.e. 10 licenses?
  2. Please elaborate this "per app/per device".?
MichaelBranscomb
Esri Frequent Contributor
Regarding your questions:
Yes, as the developer you are required to license every application you deploy. In your example, the app deployed to 10 devices requires each of the 10 app installations to be licensed for deployment. Licensing can be done via:
  • An ArcGIS Named User where the user of your app signs into ArcGIS Online or Portal for ArcGIS to unlock `Lite` as a Level 1 User or `Basic` as a Level 2 User.
  • A license key that you compile into the application. Note that license levels Standard, Advanced, and Analysis are currently only supported with the license key approach. When you receive a license key (string) to license your app, you use the same license key each time you deploy that app and you are required to keep track of how many times it is deployed and purchase the appropriate number of licenses.
The term 'per app / per device' means each application you deploy to a single device must be licensed. Effectively there is no device-wide license for multiple installed apps. As above, you can either license the app via the Named User approach where the user of the device would sign into each application on the device or license the app using the license key approach.
Resources:
License your app—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Levels, roles, and privileges—Portal for ArcGIS (10.6) | ArcGIS Enterprise
Cheers
Mike
MichaelBranscomb
Resources:
Cheers
Mike
WaldemarNowak
Does it mean that purchasing any of paid developer subscription: Builder, Professional, Premium, Enterprise still does not give me any possibility (license) to distribute my application.
These developer subscriptions have no relation to actual runtime licensing of my application. I may even use free plan "Essential" to build application, but need to purchase runtime license pack.
Can you confirm?
Regards,
Waldek
JoeHershman
Developer license is for developing, nothing else.  Any distribution requires a license to distribute the application.  As mentioned this can be purchasing a license that is embedded or connecting to AGOL/Portal and grabbing a named user license.
-Joe
WaldemarNowak
"Developer license is for developing,",
Yes, but it needs to be emphasized that developing does not require any license.
Regards,
Waldek
RichardDaniels
MVP Regular Contributor
Hello,
In regards to ArcGIS Runtime licensing standard packages. My distributor is claiming ESRI only sells standard in packs of 25 and basic in packs of 50...Our organizations only needs 5 standard licenses.
Is this true or do I just need to find a different distributor?
Rich
Nicholas-Furness
Hi Richard Daniels,
Your distributor is correct. Deployment pack sizes are:
  • Basic‌: 50
  • Standard: 25
  • Advanced: 5
  • Analysis Extension: 5
Cheers,
Nick.
BrentynHanna
Thank you Nicholas for the elaboration on the deployment pack sizes, however that is a shame. My company needs two basic licenses, but cannot justify the waste purchasing a pack for thousands of dollars to only utilize less than 5% of it. This licensing debacle is likely going to lead to the ArcGIS portions of the application being stripped out of a finished product.
As a last ditch effort, is it against ESRI's ToS to buy individual keys from a deployment pack that a different organization purchased in full?
