ArcGIS Runtime 100.6 UWP app is throwing SEHException and crashes
7080
12
09-08-2019 10:11 AM
OSINT_ENGINEER
I just started to use the ArcGIS Runtime 100.6 UWP version and wanted to create a simple app using navigation view and pages. I just installed the Esri.ArcGISRuntime.UWP nuget package. When I navigate to the page containing the map view a SEHException is raised and the UWP app crashes. Would you be so kind and help me to narrow it down?
Edition: Windows 10 Pro
Version: 1903
Build: 18362.295
Project Settings:
UWP
Target version: Windows 10, version 1903
Minimum version: Windows 10, version 1809
System.Runtime.InteropServices.SEHException
  HResult=0x80004005
  Nachricht = External component has thrown an exception.
  Quelle = <Die Ausnahmequelle kann nicht ausgewertet werden.>
  Stapelüberwachung:
<Die Ausnahmestapelüberwachung kann nicht ausgewertet werden.>
Tags (3)
AlexMenkes
System Information
      Time of this report: 10/15/2019, 11:18:42
             Machine name: CHADWICK
               Machine Id: {514A58CA-3B89-42F4-ABB4-4974E3C42D06}
         Operating System: Windows 10 Pro 64-bit (10.0, Build 18362) (18362.19h1_release.190318-1202)
                 Language: English (Regional Setting: English)
      System Manufacturer: System manufacturer
             System Model: System Product Name
                     BIOS: BIOS Date: 09/06/10 14:03:28 Ver: 09.01 (type: BIOS)
                Processor: AMD Phenom(tm) II X2 560 Processor (2 CPUs), ~3.3GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16384MB RAM
                Page File: 6555MB used, 12259MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 144 DPI (150 percent)
       System DPI Setting: 192 DPI (200 percent)
          DWM DPI Scaling: Enabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
 DirectX Database Version: Unknown
           DxDiag Version: 10.00.18362.0387 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: AMD Radeon(TM) R5 240
        Manufacturer: Advanced Micro Devices, Inc.
           Chip type: AMD Radeon Graphics Processor (0x6611)
            DAC type: Internal DAC(400MHz)
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_1002&DEV_6611&SUBSYS_210B1028&REV_00
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 9196 MB
    Dedicated Memory: 1004 MB
       Shared Memory: 8191 MB
        Current Mode: 3840 x 2160 (32 bit) (30Hz)
         HDR Support: Not Supported
    Display Topology: Extend
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.659180,0.333984), Green(0.300781,0.638672), Blue(0.149414,0.042969), White Point(0.313477,0.329102)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: DELL P2415Q
          Monitor Id: DELA0BF
         Native Mode: 3840 x 2160(p) (29.981Hz)
         Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
         Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdxc64.dll
 Driver File Version: 26.20.11015.1003 (English)
      Driver Version: 26.20.11015.1003
         DDI Version: 12
      Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 2.6
 Graphics Preemption: DMA
  Compute Preemption: DMA
            Miracast: Not Supported
      Detachable GPU: No
 Hybrid Graphics GPU: Not Supported
      Power P-states: Not Supported
      Virtualization: Paravirtualization
          Block List: No Blocks
  Catalog Attributes: Universal:False Declarative:False
   Driver Attributes: Final Retail
    Driver Date/Size: 5/8/2019 8:00:00 PM, 1972960 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
   Device Identifier: {D7B71EE2-2551-11CF-7370-0C2ABBC2D735}
           Vendor ID: 0x1002
           Device ID: 0x6611
           SubSys ID: 0x210B1028
         Revision ID: 0x0000
  Driver Strong Name: oem13.inf:cb0ae41483e32fc9:ati2mtag_R501DS:26.20.11015.1003:pci\ven_1002&dev_6611&subsys_210b1028&rev_00
      Rank Of Driver: 00D10000
         Video Accel: Unknown
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeVC1_VLD  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC  DXVA2_ModeVC1_IDCT  DXVA2_ModeWMV9_IDCT
      Deinterlace Caps: n/a
        D3D9 Overlay: Not Supported
             DXVA-HD: Not Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
            MPO Caps: Not Supported
         MPO Stretch: Not Supported
     MPO Media Hints: Not Supported
         MPO Formats: Not Supported
    PanelFitter Caps: Not Supported
 PanelFitter Stretch: Not Supported
        Monitor Name: Dell P2415Q(DP/mDP)
          Monitor Id: DELA0BE
         DDI Version: 12
      Detachable GPU: No
         WHQL Logo'd: Yes
           Vendor ID: 0x1002
           Device ID: 0x6611
         Revision ID: 0x0000
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
Sound Devices
            Description: Speakers (High Definition Audio Device)
 Default Sound Playback: Yes
 Default Voice Playback: No
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1043841B&REV_1003
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            Driver Name: HdAudio.sys
         Driver Version: 10.00.18362.0356 (English)
            WHQL Logo'd: Yes
          Date and Size: 9/4/2019 12:00:00 AM, 425472 bytes
            Other Files:
        Driver Provider: Microsoft
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Speakers (PLT_B500)
 Default Sound Playback: No
 Default Voice Playback: Yes
            Hardware ID: USB\VID_047F&PID_0116&REV_0037&MI_00
        Manufacturer ID: 65535
             Product ID: 65535
                   Type: WDM
            Driver Name: USBAUDIO.sys
         Driver Version: 10.00.18362.0001 (English)
            WHQL Logo'd: Yes
          Date and Size: 3/18/2019 12:00:00 AM, 198656 bytes
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
            Description: Microphone (PLT_B500)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
          Date and Size: 3/19/2019 00:43:37, 198656 bytes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Receiver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC52B
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: PLT_B500
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x047F, 0x0116
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Logitech Illuminated Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC318
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: USB\ROOT_HUB
| Service: usbhub
| Driver: usbhub.sys, 3/19/2019 00:43:43, 545592 bytes
| Driver: usbd.sys, 3/19/2019 00:43:43, 33592 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 3/19/2019 00:43:43, 183608 bytes
| +-+ Logitech USB Input Device
| | | Matching Device ID: usb\vid_046d&pid_c52b&mi_00
| | | Service: HidUsb
| | | Driver: hidusb.sys, 10/10/2019 16:38:26, 45568 bytes
| | | Driver: hidclass.sys, 10/10/2019 16:38:26, 211968 bytes
| | | Driver: hidparse.sys, 10/10/2019 16:38:26, 46080 bytes
| | | Driver: LogiLDA.DLL, 10/14/2016 01:55:24, 3942864 bytes
| | | Driver: LdaCx2.dll, 10/14/2016 01:55:18, 2468304 bytes
| | | Driver: msvcp110.dll, 11/5/2012 23:26:22, 661456 bytes
| | | Driver: msvcr110.dll, 11/5/2012 23:26:22, 849360 bytes
| | | Driver: vccorlib110.dll, 11/5/2012 23:26:22, 354264 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 3/19/2019 00:43:43, 46592 bytes
| | | | Driver: kbdclass.sys, 3/19/2019 00:43:43, 70968 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 3/19/2019 00:43:43, 35840 bytes
| | | | Driver: mouclass.sys, 3/19/2019 00:43:43, 66872 bytes
| | Service: usbccgp
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 365.9 GB
Total Space: 487.8 GB
File System: NTFS
      Model: Samsung SSD 850 PRO 512GB ATA Device
      Drive: 😧
 Free Space: 832.7 GB
Total Space: 5723.2 GB
File System: NTFS
      Model: WDC WD6001FZWX-00A2VA0 ATA Device
      Drive: H:
      Model: PLDS DVD+-RW DH-16AES ATA Device
     Driver: C:\WINDOWS\SYSTEM32\DRIVERS\CDROM.SYS, 10.00.18362.0001 (English), 3/19/2019 00:43:39, 173056 bytes
System Devices
     Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_84321043&REV_06\01000000684CE00000
   Driver: C:\WINDOWS\system32\DRIVERS\Rt64win7.sys, 7.46.0610.2011 (English), 6/10/2011 06:34:52, 539240 bytes
   Driver: C:\WINDOWS\system32\RtNicProp64.dll, 1.02.0000.0003 (English), 6/10/2011 06:34:52, 74272 bytes
   Driver: C:\WINDOWS\system32\RTNUninst64.dll, 1.00.0000.0005 (English), 6/10/2011 06:34:52, 107552 bytes
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
   Driver: n/a
     Name: PCI Express Root Port
Device ID: PCI\VEN_1022&DEV_9607&SUBSYS_843E1043&REV_00\3&267A616A&0&38
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.18362.0418 (English), 10/10/2019 16:38:26, 436536 bytes
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_00000000&REV_42\3&267A616A&0&A0
   Driver: n/a
     Name: AMD Radeon(TM) R5 240
Device ID: PCI\VEN_1002&DEV_6611&SUBSYS_210B1028&REV_00\4&6E074CE&0&0010
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiesrxx.exe, 26.20.11015.1003 (English), 5/13/2019 05:58:14, 507296 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atio6axx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:20, 39060896 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atioglxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:22, 32231328 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atidxx32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:48, 22712248 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atidxx64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:50, 27234032 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ATIODCLI.exe, 26.20.11015.1003 (English), 5/13/2019 05:58:20, 76704 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ATIODE.exe, 26.20.11015.1003 (English), 5/13/2019 05:58:20, 358304 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atig6pxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:14, 168352 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atig6txx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:16, 238496 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atigktxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:16, 210848 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiglpxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:16, 144288 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiu9p64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:52, 201208 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiu9pag.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:52, 165400 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiuxp64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:58, 218920 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiuxpag.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:58, 184584 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\coinst_19.10.dll, 1.00.0005.0009 (English), 5/13/2019 05:58:26, 1588640 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\aticfx32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:46, 1608200 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\aticfx64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:48, 1972960 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdocl.dll, 10.00.2841.0005 (English), 5/13/2019 05:57:56, 47276960 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdocl64.dll, 10.00.2841.0005 (English), 5/13/2019 05:57:58, 57461152 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdhdl32.dll, 5/13/2019 08:57:38, 339232 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdhdl64.dll, 5/13/2019 08:57:40, 423440 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdmantle32.dll, 26.20.11015.1003 (English), 5/13/2019 05:57:50, 23143328 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdmantle64.dll, 26.20.11015.1003 (English), 5/13/2019 05:57:52, 27211168 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativce03.dat, 12/4/2018 14:53:40, 160768 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_vi.dat, 2/12/2019 13:48:58, 325188 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_vi_nd.dat, 2/12/2019 13:49:18, 324928 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_cz_nd.dat, 2/12/2019 04:39:44, 272544 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amde31a.dat, 12/4/2018 15:40:26, 159072 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_FJ.dat, 2/12/2019 13:51:22, 268116 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_FJ_nd.dat, 2/12/2019 13:51:38, 267856 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdxc32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:42, 19100584 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdxc64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:44, 22062752 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdocl12cl.dll, 0.08.0000.0000 (English), 5/13/2019 05:57:56, 22032288 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdocl12cl64.dll, 0.08.0000.0000 (English), 5/13/2019 05:57:58, 27353504 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdicdxx.dat, 4/15/2019 04:46:20, 1060939 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiicdxx.dat, 11/6/2014 06:53:26, 737410 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_el_nd.dat, 4/9/2019 15:48:48, 374816 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdvlk32.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:00, 14798240 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdvlk64.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:00, 17051552 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amd-vulkan32.json, 4/17/2019 10:06:34, 703 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amd-vulkan64.json, 4/17/2019 10:06:58, 703 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amde34a.dat, 2/25/2019 18:14:58, 166624 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_stn_nd.dat, 2/12/2019 03:51:12, 278176 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amde34b.dat, 2/25/2019 18:15:08, 166624 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amduve32.dll, 17.00.0006.0000 (English), 5/13/2019 08:57:42, 146312 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amduve64.dll, 17.00.0006.0000 (English), 5/13/2019 08:57:42, 169192 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdmmcl.dll, 26.20.11015.1003 (English), 5/13/2019 05:57:54, 126368 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdmmcl6.dll, 26.20.11015.1003 (English), 5/13/2019 05:57:54, 148384 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiumd64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:54, 13436120 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiumd6a.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:54, 13591424 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiumdag.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:56, 10790720 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atiumdva.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:56, 12925384 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativce02.dat, 12/4/2018 14:52:00, 100832 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_cik.dat, 2/12/2019 13:47:04, 234676 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_cik_nd.dat, 2/12/2019 13:47:16, 234416 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_gl_nd.dat, 4/9/2019 15:48:48, 377664 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amde40a.dat, 3/26/2019 11:24:14, 173344 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_rv.dat, 5/3/2019 14:55:22, 354368 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdave32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:36, 118872 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdave64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:36, 134472 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_vg20.dat, 9/13/2018 12:33:42, 379200 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_vg20_nd.dat, 4/9/2019 15:48:48, 380256 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\amdefctb.dat, 3/27/2018 11:56:50, 281096 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atikmdag.sys, 26.20.11015.1003 (English), 5/13/2019 05:58:18, 53513120 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\atikmpag.sys, 26.20.11015.1003 (English), 5/13/2019 05:58:18, 592288 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\c0342342.inf_amd64_94b66b3b2b8d918d\B342310\ativvaxy_nv.dat, 2/6/2019 17:24:52, 447520 bytes
   Driver: C:\WINDOWS\system32\atieclxx.exe, 26.20.11015.1003 (English), 5/13/2019 05:58:14, 760224 bytes
   Driver: C:\WINDOWS\system32\atidemgy.dll, 4.05.7068.34970 (English), 5/13/2019 05:58:10, 467872 bytes
   Driver: C:\WINDOWS\system32\ati2erec.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:06, 69536 bytes
   Driver: C:\WINDOWS\system32\atig6txx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:16, 238496 bytes
   Driver: C:\WINDOWS\system32\atiapfxx.blb, 5/9/2019 20:23:02, 914176 bytes
   Driver: C:\WINDOWS\system32\OpenCL.dll, 2.02.0001.0000 (English), 5/13/2019 05:58:04, 134048 bytes
   Driver: C:\WINDOWS\system32\clinfo.exe, 5/13/2019 05:58:24, 348064 bytes
   Driver: C:\WINDOWS\system32\amdhcp64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:38, 190120 bytes
   Driver: C:\WINDOWS\system32\kapp_ci.sbin, 1/11/2019 18:26:26, 125488 bytes
   Driver: C:\WINDOWS\system32\kapp_si.sbin, 1/11/2019 18:27:32, 121168 bytes
   Driver: C:\WINDOWS\system32\samu_krnl_ci.sbin, 9/2/2016 11:24:22, 154384 bytes
   Driver: C:\WINDOWS\system32\samu_krnl_isv_ci.sbin, 12/12/2013 09:53:56, 138832 bytes
   Driver: C:\WINDOWS\system32\mantle64.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:32, 183200 bytes
   Driver: C:\WINDOWS\system32\mantleaxl64.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:32, 162208 bytes
   Driver: C:\WINDOWS\system32\amdgfxinfo64.dll, 5/13/2019 05:57:44, 471968 bytes
   Driver: C:\WINDOWS\system32\atieah64.exe, 5/13/2019 05:58:12, 439200 bytes
   Driver: C:\WINDOWS\system32\detoured.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:26, 19200 bytes
   Driver: C:\WINDOWS\system32\Rapidfire64.dll, 1.02.0001.0286 (English), 5/13/2019 05:58:36, 573344 bytes
   Driver: C:\WINDOWS\system32\RapidFireServer64.dll, 1.02.0000.0015 (English), 5/13/2019 05:58:36, 45976 bytes
   Driver: C:\WINDOWS\system32\amdlvr64.dll, 1.00.0016.0000 (English), 5/13/2019 05:57:50, 940448 bytes
   Driver: C:\WINDOWS\system32\vulkan-1.dll, 1.01.0106.0000 (English), 5/13/2019 05:58:38, 1010128 bytes
   Driver: C:\WINDOWS\system32\vulkan-1-999-0-0-0.dll, 1.01.0106.0000 (English), 5/13/2019 05:58:38, 1010128 bytes
   Driver: C:\WINDOWS\system32\vulkaninfo.exe, 1.01.0106.0000 (English), 5/13/2019 05:58:40, 303520 bytes
   Driver: C:\WINDOWS\system32\vulkaninfo-1-999-0-0-0.exe, 1.01.0106.0000 (English), 5/13/2019 05:58:40, 303520 bytes
   Driver: C:\WINDOWS\system32\GameManager64.dll, 5/13/2019 05:58:30, 479648 bytes
   Driver: C:\WINDOWS\system32\amdmiracast.dll, 5/13/2019 08:57:40, 553744 bytes
   Driver: C:\WINDOWS\system32\dgtrayicon.exe, 5/13/2019 05:58:28, 492448 bytes
   Driver: C:\WINDOWS\system32\AMDKernelEvents.man, 1/22/2019 17:38:10, 34488 bytes
   Driver: C:\WINDOWS\system32\amfrt64.dll, 1.04.0012.0000 (English), 5/13/2019 05:58:04, 3744672 bytes
   Driver: C:\WINDOWS\system32\amdmcl64.dll, 1.06.0000.0000 (English), 5/13/2019 05:57:52, 552864 bytes
   Driver: C:\WINDOWS\system32\amdxc64.dll, 8.18.0010.0301 (English), 5/13/2019 05:58:02, 120224 bytes
   Driver: C:\WINDOWS\system32\aticfx64.dll, 8.17.0010.1660 (English), 5/13/2019 05:58:08, 177528 bytes
   Driver: C:\WINDOWS\system32\atidxx64.dll, 5/13/2019 05:58:12, 123296 bytes
   Driver: C:\WINDOWS\system32\atimpc64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:52, 127544 bytes
   Driver: C:\WINDOWS\system32\atimuixx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:18, 124832 bytes
   Driver: C:\WINDOWS\system32\atisamu64.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:22, 158112 bytes
   Driver: C:\WINDOWS\system32\atiumd6a.cap, 5/9/2019 20:26:16, 3437632 bytes
   Driver: C:\WINDOWS\system32\ativvsva.dat, 5/9/2019 20:24:12, 157144 bytes
   Driver: C:\WINDOWS\system32\ativvsvl.dat, 5/9/2019 20:24:12, 204952 bytes
   Driver: C:\WINDOWS\system32\amdave64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:36, 134472 bytes
   Driver: C:\WINDOWS\system32\amdpcom64.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:40, 127760 bytes
   Driver: C:\WINDOWS\system32\atiadlxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:06, 1704864 bytes
   Driver: C:\WINDOWS\SysWOW64\atigktxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:16, 210848 bytes
   Driver: C:\WINDOWS\SysWOW64\atiapfxx.blb, 5/9/2019 20:23:02, 914176 bytes
   Driver: C:\WINDOWS\SysWOW64\OpenCL.dll, 2.02.0001.0000 (English), 5/13/2019 05:58:02, 120224 bytes
   Driver: C:\WINDOWS\SysWOW64\amdhcp32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:38, 167720 bytes
   Driver: C:\WINDOWS\SysWOW64\mantle32.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:32, 151968 bytes
   Driver: C:\WINDOWS\SysWOW64\mantleaxl32.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:32, 137632 bytes
   Driver: C:\WINDOWS\SysWOW64\amdgfxinfo32.dll, 5/13/2019 05:57:44, 380832 bytes
   Driver: C:\WINDOWS\SysWOW64\atieah32.exe, 5/13/2019 05:58:12, 351648 bytes
   Driver: C:\WINDOWS\SysWOW64\detoured.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:26, 19200 bytes
   Driver: C:\WINDOWS\SysWOW64\RapidFireServer.dll, 1.02.0000.0015 (English), 5/13/2019 05:58:36, 42912 bytes
   Driver: C:\WINDOWS\SysWOW64\Rapidfire.dll, 1.02.0001.0286 (English), 5/13/2019 05:58:34, 484256 bytes
   Driver: C:\WINDOWS\SysWOW64\amdlvr32.dll, 1.00.0016.0000 (English), 5/13/2019 05:57:48, 767904 bytes
   Driver: C:\WINDOWS\SysWOW64\vulkan-1.dll, 1.01.0106.0000 (English), 5/13/2019 05:58:38, 873072 bytes
   Driver: C:\WINDOWS\SysWOW64\vulkan-1-999-0-0-0.dll, 1.01.0106.0000 (English), 5/13/2019 05:58:38, 873072 bytes
   Driver: C:\WINDOWS\SysWOW64\vulkaninfo.exe, 1.01.0106.0000 (English), 5/13/2019 05:58:38, 275360 bytes
   Driver: C:\WINDOWS\SysWOW64\vulkaninfo-1-999-0-0-0.exe, 1.01.0106.0000 (English), 5/13/2019 05:58:38, 275360 bytes
   Driver: C:\WINDOWS\SysWOW64\GameManager32.dll, 5/13/2019 05:58:30, 380832 bytes
   Driver: C:\WINDOWS\SysWOW64\amfrt32.dll, 1.04.0012.0000 (English), 5/13/2019 05:58:04, 3371424 bytes
   Driver: C:\WINDOWS\SysWOW64\amdmcl32.dll, 1.06.0000.0000 (English), 5/13/2019 05:57:52, 382880 bytes
   Driver: C:\WINDOWS\SysWOW64\amdxc32.dll, 8.18.0010.0301 (English), 5/13/2019 05:58:00, 104864 bytes
   Driver: C:\WINDOWS\SysWOW64\aticfx32.dll, 8.17.0010.1660 (English), 5/13/2019 05:58:08, 156880 bytes
   Driver: C:\WINDOWS\SysWOW64\atidxx32.dll, 5/13/2019 05:58:10, 106400 bytes
   Driver: C:\WINDOWS\SysWOW64\atimpc32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:50, 107160 bytes
   Driver: C:\WINDOWS\SysWOW64\atisamu32.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:22, 135072 bytes
   Driver: C:\WINDOWS\SysWOW64\atiumdva.cap, 5/9/2019 20:26:18, 3471376 bytes
   Driver: C:\WINDOWS\SysWOW64\ativvsva.dat, 5/9/2019 20:24:12, 157144 bytes
   Driver: C:\WINDOWS\SysWOW64\ativvsvl.dat, 5/9/2019 20:24:12, 204952 bytes
   Driver: C:\WINDOWS\SysWOW64\amdave32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:36, 118872 bytes
   Driver: C:\WINDOWS\SysWOW64\amdpcom32.dll, 26.20.11015.1003 (English), 5/13/2019 08:57:40, 107368 bytes
   Driver: C:\WINDOWS\SysWOW64\atiadlxx.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:08, 1236384 bytes
   Driver: C:\WINDOWS\SysWOW64\atiadlxy.dll, 26.20.11015.1003 (English), 5/13/2019 05:58:08, 1236384 bytes
   Driver: C:\Program Files\AMD\CCC2\Install\ccc2_install.exe, 8.911.0003.3000 (English), 5/13/2019 05:58:24, 174772960 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.stz, 19.20.0001.0000 (English), 5/13/2019 05:57:48, 103456 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.itz, 3/22/2019 16:12:48, 1999 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.ctz, 4/17/2019 06:58:22, 8590 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_32.dll, 26.20.11015.1003 (English), 5/13/2019 05:57:46, 246688 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_64.dll, 26.20.11015.1003 (English), 5/13/2019 05:57:46, 300960 bytes
   Driver: C:\WINDOWS\system32\coinst_19.10.dll, 1.00.0005.0009 (English), 5/13/2019 05:58:26, 1588640 bytes
     Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1106&DEV_0415&SUBSYS_838F1043&REV_00\004063FFFF63400000
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:41, 16936 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:41, 56848 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:41, 30224 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ataport.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:41, 222728 bytes
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AAB0&SUBSYS_AAB01028&REV_00\4&6E074CE&0&0110
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:37, 114688 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:37, 98304 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:37, 390656 bytes
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_84431043&REV_40\3&267A616A&0&88
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&267A616A&0&A4
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_84431043&REV_40\3&267A616A&0&A1
Device ID: PCI\VEN_1022&DEV_9608&SUBSYS_843E1043&REV_00\3&267A616A&0&48
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_84431043&REV_00\3&267A616A&0&B2
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 100664 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 475144 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 545592 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_84431043&REV_00\3&267A616A&0&9A
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_84431043&REV_00\3&267A616A&0&92
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_841B1043&REV_40\3&267A616A&0&A2
Device ID: PCI\VEN_1022&DEV_9603&SUBSYS_843E1043&REV_00\3&267A616A&0&10
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
   Driver: n/a
     Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_84431043&REV_00\3&267A616A&0&A5
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 30208 bytes
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
   Driver: n/a
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_84431043&REV_40\3&267A616A&0&A3
   Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.18362.0267 (English), 10/10/2019 16:38:26, 19256 bytes
Device ID: PCI\VEN_1022&DEV_9609&SUBSYS_843E1043&REV_00\3&267A616A&0&50
Device ID: PCI\VEN_1022&DEV_9601&SUBSYS_843E1043&REV_00\3&267A616A&0&00
   Driver: n/a
     Name: Renesas USB 3.0 eXtensible Host Controller - 0.96 (Microsoft)
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_03\FFFFFFFFFFFFFFFF00
   Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.18362.0207 (English), 10/10/2019 16:38:27, 531976 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.18362.0207 (English), 10/10/2019 16:38:27, 131960 bytes
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_84431043&REV_00\3&267A616A&0&B0
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_84431043&REV_00\3&267A616A&0&98
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_84431043&REV_00\3&267A616A&0&90
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.18362.0145
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.18362.0145
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.18362.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.18362.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.18362.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.18362.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.18362.0001
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.18362.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.18362.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.18362.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.18362.0001
LogMeIn Video Encoder,0x00200000,1,1,racodec.ax,4.01.0000.13058
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.18362.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.18362.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.18362.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.18362.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.18362.0418
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.18362.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.18362.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.18362.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.18362.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.18362.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.18362.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.18362.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.18362.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.18362.0001
LogMeIn Video Decoder,0x00800000,1,1,racodec.ax,4.01.0000.13058
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.18362.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.18362.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.18362.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.18362.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.18362.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.18362.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.18362.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.18362.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.18362.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.18362.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.18362.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.18362.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.18362.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.18362.0001
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.18362.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.18362.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.18362.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.18362.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.18362.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.18362.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.18362.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.18362.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.18362.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.18362.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.18362.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.18362.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.18362.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.18362.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.18362.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.18362.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.18362.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.18362.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.18362.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.18362.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.18362.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.18362.0001
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.18362.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.18362.0001
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.18362.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.18362.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.18362.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.18362.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.18362.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.18362.0145
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.18362.0145
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.18362.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.18362.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.18362.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.18362.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.18362.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.18362.0001
Audio Capture Sources:
Microphone (PLT_B500),0x00200000,0,0,qcap.dll,10.00.18362.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.18362.0418
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.18362.0418
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.18362.0418
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.18362.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.18362.0001
WDM Streaming Capture Devices:
PLT_B500,0x00200000,3,2,ksproxy.ax,10.00.18362.0001
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
AMD HD Audio DP out #0,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
AMD HD Audio DP out #1,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
HD Audio SPDIF out 2,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.18362.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.18362.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.18362.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.18362.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.18362.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: Speakers (PLT_B500),0x00200000,1,0,quartz.dll,10.00.18362.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
  mfcore.dll, 10.00.18362.0418
  mfreadwrite.dll, 10.00.18362.0001
  mfcaptureengine.dll, 10.00.18362.0001
  mfsensorgroup.dll, 10.00.18362.0207
  windows.media.dll, 10.00.18362.0145
  frameserver.dll, 10.00.18362.0207
  fsclient.dll, 10.00.18362.0207
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8, AMDhwDecoder_64.dll, 26.20.11015.1003
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.18362.0418
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.18362.0001
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.18362.0001
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.18362.0418
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.18362.0001
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.18362.0001
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.18362.0001
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.18362.0001
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.18362.0001
  WebpImageExtension
  HEIFImageExtension
  VP9VideoExtensionDecoder
Video Encoders:
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.18362.0001
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.18362.0001
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.18362.0001
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.18362.0001
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.18362.0001
  HEIFImageExtension
  VP9VideoExtensionEncoder
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.18362.0001
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.18362.0001
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.18362.0001
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.18362.0001
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.18362.0001
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.18362.0387
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.18362.0418
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.18362.0001
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.18362.0145
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.18362.0175
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.18362.0418
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.18362.0418
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.18362.0145
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.18362.0001
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.18362.0001
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.18362.0175
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.18362.0001
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.18362.0418
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.18362.0418
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.18362.0001
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.18362.0001
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.18362.0418
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.18362.0418
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.18362.0001
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.18362.0145
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.18362.0001
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.18362.0001
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.18362.0145
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.18362.0001
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.18362.0001
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.18362.0001
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.18362.0001
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.18362.0001
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.18362.0418
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.18362.0418
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 125730739576, type 5
Event Name: PerfWatsonVS12Data
Response: Not available
Cab Id: 0
Problem signature:
P1: PerfWatsonTcdb
P2: 0
P3: 0
P4: 0
P5: 0
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Cab Id: 0
Problem signature:
P1: PerfWatsonTcdb
P2: 0
P3: 0
P4: 0
P5: 0
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P1: PerfWatsonTcdb
P2: 0
P3: 0
P4: 0
P5: 0
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Fault bucket 2139000128009205741, type 5
Event Name: BEX64
Cab Id: 0
Problem signature:
P1: ScriptedSandbox64.exe
P2: 16.0.29311.71
P3: 5d793122
P4: d3d11.dll
P5: 10.0.18362.387
P6: 7e72d1cb
P7: 00000000000a6eb1
P8: c0000409
P9: 0000000000000007
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: PerfWatsonTcdb
P2: 0
P3: 0
P4: 0
P5: 0
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Event Name: BEX64
Cab Id: 0
Problem signature:
P2: 16.0.29311.71
P3: 5d793122
P4: d3d11.dll
P5: 10.0.18362.387
P6: 7e72d1cb
P8: c0000409
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: PerfWatsonTcdb
P2: 0
P3: 0
P4: 0
P5: 0
P6:
P7:
P8:
P9:
P10:
+++ WER7 +++:
Fault bucket 1165910571507319892, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: MicrosoftEdgeCP.exe
P2: 11.0.18362.1
P3: 10.0.18362.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER8 +++:
Fault bucket 125946542339, type 5
Event Name: ScriptedDiagFailure
Cab Id: 0
Problem signature:
P1: Microsoft Windows.NetworkDiagnostics.4.0
P2: Default
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER9 +++:
Fault bucket , type 0
Cab Id: 0
Problem signature:
P2: Default
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
dotMorten_esri
Esri Notable Contributor
@Alex: This thread is about UWP throwing, but you're mentioning WPF. I think you started another thread specific to WPF (or are you seeing the same issue with UWP too?)
AlexMenkes
Sorry, no, just WPF.  And I did start a new thread.  TY
