A synchronization problem on WPF mobile application
4561
12
04-26-2018 09:00 AM
sailiTang
I am using ArcGIS Runtime SDK for .NET WPF 100.2 to develop mobile applications. I got a problem on “synchronize” function. When the app generates an offline database and then collect data, it works well, but the new collected data cannot be synchronized to our geodatabase when I press the “Synchronize” button. For the Synchronized function, I am using the code in this sample https://developers.arcgis.com/net/latest/wpf/sample-code/editandsyncfeatures.htm. The synchronization is successful, but I cannot find the new data in our geodatabase. However, after I edit these new data(such as changing some attributes’ values), it can be synchronized to geodatabase. It seems like “synchronize’ cannot identify new data, but edited data. Is it normal? In my code, the SyncDirection is Bidirectional, I run the code step by step and the synchronize always finished successfully. Does who know what reason causes this problem? How I fix it? Thanks
Saili
sailiTang
Hi Joe,
In addition, I am using our own services.
Saili
AnttiKajanus1
Another thing that might be affecting could be if you have enabled editor tracking on your feature service. Could you confirm if that is enabled?
AnttiKajanus1
What kind of setup you have that you use from the runtime? Are the services running in ArcGIS Online or on Enterprise? Is versioning enabled?
Can you show me the exact code that you are using with the sync? If you try to use OfflineMapSyncTask, does that work?
