100.8: New MMPK Issue
5468
12
05-12-2020 08:51 AM
MarkCederholm
Heads up, looks like 100.8 has introduced a new MMPK problem, centered around GetLegendInfosAsync.  As soon as I can isolate the problem and set up a working example, I'll get it off to tech support.  Has anyone else seen this yet?
"Cannot call this method in this context: Object failed to load, unable to execute task."
This is only happening with a particular MMPK and not the others I work with, so I wouldn't be surprised if it's a symbology issue.
MichaelBranscomb
Esri Frequent Contributor
Mark,
What changes were required to the data model?
Mike
MarkCederholm
Annotation symbols are defined in the annotation classes.  Changing the symbol is not allowed, so new classes were created and the old ones removed.
MarkCederholm
Here's a workaround, using ArcObjects, that can be applied to the temporary file GDB as part of an automated workflow.  As far as I can tell, it is currently impossible to do the same thing in ArcGIS Pro*, so this change must be applied before the annotation feature class is upgraded.
using System.Collections.Generic;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.DataSourcesGDB;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Geodatabase;
namespace UpdateAnnoSym
	public static class AnnoHelper
		public static void UpdateAnno(string sWorkspacePath, string sAnnoClass)
			// Open workspace and annotation class
			// [Assumes a file GDB]
			IWorkspaceFactory pWSF = new FileGDBWorkspaceFactoryClass();
			IWorkspace pWS = pWSF.OpenFromFile(sWorkspacePath, 0);
			IFeatureWorkspace pFWS = pWS as IFeatureWorkspace;
			IFeatureClass pFC = pFWS.OpenFeatureClass(sAnnoClass);
			// Get the class extension
			object ext = pFC.Extension;
			IAnnotationClassExtension pAnnoExt = ext as IAnnotationClassExtension;
			// Get symbol collection and loop through symbols
			bool bUpdated = false;
			ISymbolCollection pSC = pAnnoExt.SymbolCollection;
			Dictionary<int, ISymbol> SymbolTab = new Dictionary<int, ISymbol>();
			pSC.Reset();
			while (true)
				// Check text symbol for HSL color definition
				ISymbolIdentifier pSI = pSC.Next();
				if (pSI == null)
					break;
				ISymbol pSym = pSI.Symbol;
				ITextSymbol pTextSym = pSym as ITextSymbol;
				IColor pCol = pTextSym.Color;
				if (!(pCol is IHlsColor pHSL))
					continue;
				// Replace with RGB color
				int iID = pSI.ID;
				IClone pClone = pSym as IClone;
				pTextSym = pClone.Clone() as ITextSymbol;
				int iRGB = pHSL.RGB;
				IRgbColor pRGB = new RgbColorClass() { RGB = iRGB };
				pTextSym.Color = pRGB;
				SymbolTab[iID] = pTextSym as ISymbol;
				bUpdated = true;
			if (!bUpdated)
				return;
			// Update annotation classes
			IAnnotateLayerPropertiesCollection pAPC = pAnnoExt.AnnoProperties;
			int iCount = pAPC.Count;
			for (int i = 0; i < iCount; i++)
				pAPC.QueryItem(i, out IAnnotateLayerProperties pAnnoProp, out IElementCollection pPlaced, out IElementCollection pUnplaced);
				ILabelEngineLayerProperties pLabelProp = pAnnoProp as ILabelEngineLayerProperties;
				int iID = pLabelProp.SymbolID;
				if (!SymbolTab.ContainsKey(iID))
					continue;
				pLabelProp.Symbol = SymbolTab[iID] as ITextSymbol;
			// Update symbol collection
			// [Not really necessary?]
			ISymbolCollection2 pSC2 = pSC as ISymbolCollection2;
			foreach (int iID in SymbolTab.Keys)
				pSC2.Replace(iID, SymbolTab[iID]);
			// Save changes
			IAnnoClassAdmin3 pAdmin = pAnnoExt as IAnnoClassAdmin3;
			pAdmin.UpdateProperties();
*Feel free to vote up this idea if you agree with it: Geoprocessing Toolset for Creating and Manipulating Annotation Feature Classes
