zoom level is not correct
1412
12-18-2019 10:09 AM
RudySanchez
I am using view.zoom to get the current zoom level. while the map itself is zooming in and out correctly the value is incorrect. for example. The map starts at zoom level 9. I will scroll in and the value changes
10
11
12
13
14
15
16
17
then I scroll out and the zoom value increases instead of decreasing
18
Then after that initial zoom out, the value starts to decrease again.
17
16
This causes an issue because I am using that value to determine if I am going to display a parcel layer.
view.on('mouse-wheel', () => {
      const _coreLogicLayer = this.props.coreLogicLayer
      const _layer = map.layers.items.find(x => x.title === 'Core Logic')
      if (view.zoom >= 16 && !_layer) {
        map.add(_coreLogicLayer)
        const _layer0 = map.layers.items.find(x => x.title === 'Core Logic')
        map.reorder(_layer0, 0)
      } else if (view.zoom < 16 && _layer) map.remove(_coreLogicLayer)
I am using
"esri-loader": "^2.12.0"
in my react application.
Gianna_BBSRC
Hi Rudy,
view.zoom only logs the current zoom level on mouse-wheel (i.e. the zoom level BEFORE the mouse-wheel action).
There is a way to log the current zoom level of the view with watchUtils.
watchUtils.watch(view, "zoom", function(zoom) {
    console.log(zoom);
Don't forget to add the require at the beginning of your script
require(["esri/core/watchUtils"], function(watchUtils) { /* code goes here */ });
