Not able to view ArcGIS non shared Scene Layer with BuildingSceneLayer even though I have signed in and the file is from my Portal
710
07-11-2019 09:38 PM
GeorgyFelix
I am viewing BuildingSceneLayer using ArcGIS Javascript API.
I want to display a SceneLayer which is not shared as public in the ArcGIS portal.
When I try viewing it I get
Sceenshot
When I view in Codepen
https://codepen.io/arnofiva/pen/c410babb5384945a12b1d8206ebe27ce?editors=1010
require([
 "esri/Map",
 "esri/views/SceneView",
 "esri/layers/BuildingSceneLayer"
], function(Map, SceneView, BuildingSceneLayer) {
 // Create Map
 var map = new Map({
 basemap: "terrain",
 ground: "world-elevation"
// Create the SceneView
 var view = new SceneView({
 container: "viewDiv",
 map: map,
 camera: {
 position: [-74.0338, 40.6913, 707],
 tilt: 81,
 heading: 50
// Create SceneLayer and add to the map
 var sceneLayer = new BuildingSceneLayer({
 portalItem: {
 popupEnabled: false
 map.add(sceneLayer);
sceneLayer.when().then(function() {
 view.goTo(sceneLayer.fullExtent);
I get a popup for logging in. How do I enable that in my code?
