View license usage without administrative privileges or alternatively view License usage from other computer
2127
11-24-2022 02:20 AM
Bart-JanSchoenmakers
Hello all,
We have our ArcGIS license manager on a computer where only our colleagues from the system administrator group have administrative privileges.
Whenever we want to view the license usage we have to ask them for help.
I would like to know if there exists a possibility to view the license usage as a non administrator through ArcPY script or view the license usage from another computer which has administrative privileges?
Thanks all,
Bart-Jan Schoenmakers
Statistics Portugal
I solved the problem. You can use the lmutil program which is installed with the license server. Ths don't need any administrative privileges.
You can list the licences with “lmutil lmstat”
  • Example: lmutil lmstat -c -a "Path to License File"
You can remove the license with “lmutil lmremove”
  • Example: lmutil lmremove -c "Path License File" FEATURE USER CLIENT_MACHINE “Display Information”
The syntax needs some attempts, with the following links you’ll find information how to use these commands:
Bart
Bart
