Why am I getting a 000824 when running model builder?
4422
09-30-2015 05:40 PM
RyanHowell1
I am using ArcGIS 10.2, using a model to use the extract by mask tool multiple times. When I run the model, it runs through all of my tools and has the 000824 error for each one (tool is not licensed). The box is checked under extensions for Spatial Analyst.​ How do I clear this error and run my model?
DanPatterson_Retired
to confirm Using Extensions in ArcGIS—Help | ArcGIS for Desktop
this is where you are checking the license on and you are funning on a standalone machine with a standalone license ...or is it one of the other configurations that has some cavaets associated with them?
also 10.3 has a huge list of bug fixes ... maybe it is a bug and has been fixed
http://downloads.esri.com/support/downloads/other_/1031-IssuesAddressedList.pdf
RyanHowell1
Yes, it is under the licenses under extensions where I checked the box. I
am using it on a college campus, so I think it is a stand alone machine
with a stand alone license, but I would have to ask someone to be sure.
JayantaPoddar
Can you run the open the Extract by Mask tool from ArcToolBox?
Think Location
RyanHowell1
Running extract by mask works fine outside the model
curtvprice
(EDITED - just checked this and it doesn't work the way I remembered.)
When your model is seen as a tool it should check for the Spatial Analyst extension and you'll see a "lock" on the tools if the license isn't available.
Your model won't run from ArcMap if you try without extension not turned on; you'll get this popup:
I'm guessing you may be running the tool from ArcCatalog and haven't checked the box there?
If you are running the model from a Python script you would need to check out the extension in your Python script first with arcpy.CheckOutExtension(). Interestingly with 10.2.2 I'm getting a different error number.
