Split by attribute in Model Builder
9915
11
06-18-2015 07:12 AM
JonathanMori1
I have been attempting this model but I am having a little trouble with one part. The model exports from a SQL Spatial Database using Data Interop Extension , and merges them into one feature class. The problem I am having is that it needs to be split into separate shapefiles based on the "layer" field. I did some research and found that  "Iterate Field Values" would be able to do this, but I cannot get it to work right. I attached the toolbox and the Model that I am referring to is M4ExportModel_Points2. I was wondering if anyone could see what I'm missing or what I am doing wrong.
SepheFox
I'm assuming it just stops at the iterator. I just noticed the problem. After the iterator you need to insert Select by Attribute, and use the Value variable in your selection query, then you can connect that to copy features.
SepheFox
Can you just put in a screenshot of your model? It is much easier than downloading a zip, etc.
JonathanMori1
OK, here is the section after the merge where I am trying to split by attributes. The Expression is ("Layer"=%Value%)
SepheFox
You didn't mention what happens when you run the model, but try replacing Feature Class to Feature Class with Copy Features.
JonathanMori1
OK Here is the Iterator part I'm having issues with. It runs fine up until then
Executing (Iterate Field Values): IterateFieldValues C:\Users\morij\Desktop\Projects\M4Testing_062015\ModelTest\M4ExportMerge_PointUTM Layer Long true true 0
Start Time: Thu Jun 18 10:56:31 2015
Succeeded at Thu Jun 18 10:56:31 2015 (Elapsed Time: 0.01 seconds)
SepheFox
JonathanMori1
What I had to do is create another model, because I got it somewhat working, but it would go through whole the model again for each iteration and take forever.  The new one only has the "Iterate Feature Selection" as seen below, it uses the export/merge/projected shapefile from the other model.
This seems to be working pretty well.
SepheFox
Great! You can make a submodel out of this and put it in your larger model.
JonathanMori1
I am trying the copy features tool as you suggested and Iterate Feature Selections with a "group by" Layer
DanPatterson_Retired
If you feel like splitting it up as a separate process see Split Layer By Attribute (for version 10.3, a toolbox can be generated for older versions if needed)
