Set output dataset path to predefined folder in modelbuilder
1321
06-02-2020 07:18 PM
BriannaStone
Hello All,
I feel that this is something that should be really simple and I feel like I had done it once before a long time ago. I have a model to where as things process they are moving from one folder to the next. My goal is to make this tool so that I can reuse it for various projects and am trying to make the folder entry portion simple, instead of having to enter in the information in multiple locations. So how do I reference variable "Test Folder" that has path "C:\user\stuff\testing_folder" into the process output so that it can say something like 'Test Foler'\%Name% instead of C:\user\stuff\testing_folder\%Name%.
I do request that no one suggests going into environments and setting the workspace because that does not solve the problem. The tools will not accept %Name% in the output field even if each tool has a different current workspace set.
Please and Thank you for your help in advance!
Bri
DanPatterson
MVP Esteemed Contributor
Are you using model parameters?
Model parameters—ArcGIS Pro | Documentation
The 'P' will allow you to set a default value.
This can be used in conjunction with inline substitution
Inline variable substitution—ArcGIS Pro | Documentation
Have a look and then decide if you need to show your model to get more feedback.
... sort of retired...
