ModelBuilder - Iterators and Map Packages
4206
03-04-2015 01:51 AM
OrlaMcManus2
Hi all,
I have created a model using 'iterate features' to prdoduce 20 clips of a dataset using the local authorites as the clip. I would like to create 20 map packages with the original mxd plus the relevant clip product. I would like to have all of this in 1 model but I understand that 2 iterators cannot be used in 1 model.
Could anyone help me out here? Thanks!
KishorGhatage
If you are familiar with scripting use Python ( Arcpy). I am not expert however I will try to create a small script.
However here is an approach of model in model which helps to use two iterators.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Hope this is helpful
Regards
Kishor
