fuzzy membership in modelbuilder not allowing modification
1581
10-13-2011 02:45 PM
JamieKass
I have an interesting error: When I try to change the parameters on Fuzzy Membership in ModelBuilder, the values revert back to the default. I have a relatively complicated model, and this might have something to do with it. When I run the tool outside ModelBuilder, I can make the changes I need to the parameters.
NicholasHunsaker
I too...am trying to run the Fuzzy Membership on simultaneous rasters in ModelBuilder and am running in to the problem (or bug) where it lets me apparently change the "Membership Type" but ends up defaulting to "MSSmall" irrespective of whether I change it in the batch table.  To put this in perspective, the "Remap" tool CAN be used to batch reclassify rasters, but the Fuzzy Membership tool defaults back to MSSmall even though it deceptively shows it processing with the chosen membership type.
Attached are two pics showing the ModelBuilder diagram I built and the resulting interface whence double-clicked in ArcCatalog.
MelanieLanglois
Almost 4 years latter and I am having this same issue (with 10.1), did anyone find a fix?
