Excluding NULL values in Delete Identical geoprocessing tool
2211
08-21-2019 11:53 AM
by Anonymous User
Not applicable
I am using the Delete Identical tool in model builder to remove identical features using unique values in a specific field. In that field there are a few NULL values that are getting deleted since they are technically duplicates. Is there a way to add an expression or something similar so that the Delete Identical tool ignores NULL values and doesn't delete them?
DanPatterson_Retired
You might have to add a pre-step to select by attributes those attributes that are not Null, then the delete identical tool.
I would use the find identical tool for testing first though
Find Identical—Data Management toolbox | ArcGIS Desktop
by Anonymous User
Not applicable
Thank you, I was over thinking this one and forgot about select by attributes.
DuncanHornby
MVP Notable Contributor
To compliment Dan's answer you should know that ALL geo-processing tools honour selections first. So by applying a selection to a layer that is how you can process a subset of data.
