Convert Polygon to Points in ModelBuilder.
1410
10-07-2013 01:18 PM
UsmanYousaf1
Hi Everyone!
I have a set of parcels and i want to generate centroids (Preferably label Points) of those parcels in the model builder with all existing attributes. I am using 10.1 Standard. of all the options i have looked at, none seems to work for me. Following are some options that i have tried.
1. Feature to Point (ArcGIS Tool) ==> needs Advanced licence.
2. ETGeoWizard  ==> cannot use in model builder.
3. Generate Random Points (ArcGIS Tool) ==> Does not carry the polygon attributes over to points.
4. Calculate X & Y in model Builder, make a table, Make XY Event layer and Save as Feature Class ==> Problem Calculating XY
any thoughts would be appreciated.
Thanks Everyone!
DarrenWiens2
You can add ET GeoWizards tools to your model by adding the toolbox to ArcMap, found in:
C:\Program Files (x86)\ET SpatialTechniques\ET GeoWizards 10.2 for ArcGIS 10.1 (OR WHEREVER YOUR ET_GW RESIDES)
...add dragging the tool into your model.
edit: I have the full version of ET GeoWizards, so no guarantees that this works in the free version.
