buffer lines and points at same time
1658
07-09-2020 10:21 AM
GinaBrewer-Mills
Does anyone know if there is a way to say use "Select By Attributes" on both a point and line feature with the same attribute, then buffer that selection with a graphic buffer?
I am basically trying to select some points and lines together and create a bounding box around them. Then I need to retrieve the bounding box coordinates.
Thanks for any help or advice
DanPatterson
MVP Esteemed Contributor
Use Envelope in
Minimum Bounding Geometry—Data Management toolbox | Documentation
on both the points and poly* features to get both their extents,
then use
Append—Data Management toolbox | Documentation
on both the Envelop files and finally
do a Minimum bounding Geometry Envelope on the resultant.
Add Geometry Attributes—Data Management toolbox | Documentation
to that file to get the extent coordinates
... sort of retired...
GinaBrewer-Mills
Thanks Dan I will give it a shot!
DanPatterson
Gina Brewer-Mills
I would be remiss if I didn't provide a numpy lesson
import numpy as np
from numpy.lib.recfunctions import structured_to_unstructured as stu
from arcpy.da import FeatureClassToNumPyArray
f0 = r"C:\Git_Dan\npgeom\Project_npg\npgeom.gdb\Polygons2"
f1 = r"C:\Git_Dan\npgeom\Project_npg\tests.gdb\sq"
a0 = stu(FeatureClassToNumPyArray(f0, ["SHAPE@X", "SHAPE@Y"], explode_to_points=True))
a1 = stu(FeatureClassToNumPyArray(f1, ["SHAPE@X", "SHAPE@Y"], explode_to_points=True))
a01 = np.concatenate((a0, a1), axis=0)
min_xy = np.min(a01, axis=0)
max_xy = np.max(a01, axis=0)
min_xy, max_xy
(array([ 300000.0,  5000000.0]), array([ 300025.0,  5000018.0]))
