Add Field & Delete Field Removes Layer from TOC
4294
05-31-2016 02:54 PM
ChrisHolmes
Hello everyone, I have the following model which adds a field to site_polygon. It works fine but it also removes site_polygon from the TOC. Which I don't understand why this happens. I can drag site_polygon back onto the map from Catalog but it will not have any of the symbology that it had before. I find it works the same if I use "Delete Field" also.
Thanks. Any ideas appreciated.
Chris
FC_Basson
Are you overwriting the site_polygon layer in the process?
FC_Basson
ChrisHolmes
Yes I am. So now when I think about it, it makes sense. But it's not what I want to do. Site_polygon is a empty layer, all I want to do is to copy a parcel from the OPF PARCEL layer and paste it into site_parcel, without having it removed from TOC and losing it's symbology.
Is there a better way I should be looking into doing this?
Thanks
curtvprice
Maybe you could be using the Append tool so you don't need to delete and re-write the dataset?
ChrisHolmes
Thanks Curtis, I'll check it out.
Chris
