I recently needed to share an image of a model in modelbuilder to an external client who does not have ESRI software. Through the model builder tab > Model > Export I created a PDF of the model. It all looked fine for me.
So I attached it to an email and sent it to the client. For them the text looked like morse code so the PDF was useless.
It appears that the export process does not embed fonts and there is no UI for adjusting options when exporting to PDF in model builder.
I asked the ESRI document assistant AI and that confirms its a lack of embedded fonts but erroneously points you to the export tool under the share tab in ArcPro.
So my idea is simply if you are not going to expose PDF options such as embedding fonts through that export button on the model builder tab then please embed fonts as a default so people can actually read the model!
As it stands if your clients don't have those fonts (and not everyone has ESRI software) then sharing a PDF of the model is completely pointless as no one can read it.
Hi @BBicking1 ,
Thanks for looking into this idea. Would I mind, not at all, but I don't think its really a choice. PDF is a very common format that is used by all sorts of devices running different OS with different setups. If ESRI are going to offer an option to allow you to export to PDF, which would be sensible as so many people use it, then to ensure all people can actually view it, it needs the fonts embedded.
A 1MB jump in size does seem excessive but in to days broad band society quite easy to consume.
I would have though a simple option for the developers would be to have a check box in the options section of ArcPro. Ticked on - embedded fonts, guaranteed to work but large file size, ticked off - smaller file size, only viewable if system has those fonts. This allows the end user to choose when needed and is easy to do. Of cause this would need to be documented in the help file if they go down that route.
@DuncanHornby wrote:I recently needed to share an image of a model in modelbuilder to an external client who does not have ESRI software. Through the model builder tab > Model > Export I created a PDF of the model. It all looked fine for me.
My suggestion is simple: if PDF export options such as font embedding are not going to be exposed through the ModelBuilder export interface, then fonts should be embedded by default. Otherwise, the exported document risks turning clear model text into something that resembles a Morse code tap pattern to anyone who doesn't have the required fonts installed.
I ran into something very similar recently, and I have the same question. If the exported PDF looks correct on the machine that created it but becomes unreadable for someone without the same fonts installed, that seems like a major limitation for sharing models externally. The whole point of exporting to PDF is to create a portable document that can be viewed consistently, regardless of what software the recipient has.
I also have the same question about why font embedding isn't enabled by default, especially if there aren't any export options available in the ModelBuilder PDF export workflow. Having text turn into unreadable symbols for clients makes the export effectively useless for collaboration and review. At the very least, it would be helpful if ESRI either embedded the fonts automatically or provided a setting to control PDF font handling during export.
