Tutorial data
5058
07-16-2013 09:58 AM
JuliaGalindo
Hi, I would like to explore the schematics extension. Is there a way to get the tutorial data from the Resource Center? Where can I find it?
I only succeed in getting the network analysis data.
thanks,
Julia
RickAnderson
It isn't on the resource center.  You need to install from ArcTutor, which should be part of your ArcGIS package.  When you run that installation, just expand the Extensions section and turn on Schematics.
RickAnderson
Correct language from the resource topic:
To work through the ArcGIS for Desktop tutorials, you need to install the tutorial data from the ArcGIS for Desktop Tutorial Data setup, which is part of the ArcGIS for Desktop installation download or media. If the tutorial data has been installed on your system, look for it in C:\arcgis\ArcTutor (the default installation location). In many cases, you will need write access to that location to perform the tutorial.
JuliaGalindo
Ok, thanks I will check!
