Stacked Addresses Labeling
2764
03-28-2016 01:44 PM
DaveTenney
All,
  was just curious if anyone else has run into the problem of labeling stacked points?
in my case in address points of an apartment complex are stacked on one another and i was sure if there was a way to cleanly label all the main address numbers? We are currently using 10.2.2.
thanks
dave
WesMiller
Do you have a field that indicates primary address? You could use Using label classes to label features from the same layer differently—Help | ArcGIS for Desktop
