Save streched values along color ramp as raster function template
2428
07-09-2015 07:59 AM
IgnacioGuerrero
I need to create a standard color representation for  a large set of raster files. I use a  min-max stretch function and I override the default values (calculated from the file) with standard min-max values (for example 0 to100). Then I select a color ramp. The display looks good for the current file. Next, I export as a raster function template (from the Layer Properties/Symbology dialog). Apparently the raster function template does not honor the custom min-max (0 to 100) but it reverts to the default  values calculated from the file. Thus when I apply the raster function template, I don't et the standard color scale 0 to 100. Is this a bug? Is there a way to force the raster function template to store standard min-max values?
Ignacio
