Query on user name in definition query
4870
09-16-2015 08:39 AM
David_van_Riel
Hi All,
I want an ArcMap definition query so that the layer only shows features based off of what the computer login user name is.
I have a field named USERNAME that would contain different user names.  Then I would use the definition query to only show and label those features that have the same computer login name.  For example: USERNAME = SYSTEM_USER.
I can get user name and PC name to label using Python but I want to query on user name and that uses SQL.
Can it be done?
David
MahtabAlam1
I am afraid this can't be done as SQL expression doesn't support advanced syntax like label expressions.
But you could write a simple python addin extension A Python Addin Extension
Which can be used to apply to definition query to your layer something like below:
import arcpy
import pythonaddins
import getpass
class ExtensionClass1(object):
    """Implementation for pyaddins_addin.extension2 (Extension)"""
    def __init__(self):
        # For performance considerations, please remove all unused methods in this class.
        self.enabled = True
    def startup(self):
        pass
    def applyDefQuery(self):
        lyr = arcpy.mapping.ListLayers(arcpy.mapping.MapDocument("CURRENT"))[0]
        if lyr.supports("DEFINITIONQUERY"):
            lyr.definitionQuery = "USERNAME='{0}'".format(getpass.getuser().upper())
            arcpy.RefreshActiveView()
        return
    def newDocument(self):
        self.applyDefQuery()
        return
    def openDocument(self):
        return
MichaelRobb
Honored Contributor
Do you think this is doable in the web world?  (Using ArcGIS Server -- Web application builder) ?  thoughts?
my initial thought is that this sounds like a job for SOIs...
