Printing problem
2373
11-14-2013 04:34 AM
by Anonymous User
Not applicable
Original User: jamesh
I have a map that selectively won't print parts of certain features. I've tried printing to vairous real & virtual printers (pdf, tif etc). I tried using different map files (mxds). There are no graphics or other features that might be in the way. These are personal geodatabase features. (this is a problem I've found quite frequently with file geodatabases, which is why I avoid using them). What is especially bizzare, parts of features are not drawn- i.e. a single line feature with 2 verticies has part of its middle not printed.
Any idea for a solution, other than drawing graphics to mimic the missing features?
JimCousins
I have not experienced these issues. I would try using the "Repair Geometry" tool and see if that corrects issues for you (These appear to be generated in software other than ArcMap). Another tact is to export the layer to a new shapefile, and see if that helps you.
Regards,
Jim
by Anonymous User
Not applicable
-'repair geometrey' didn't work.
-exporting feature class to shapefile worked - and re-importing the shapefile back into the geodatabase also worked..
I'll keep this in mind - if all else fails, export & re-import.
Thanks for your help, you saved my day!
JimCousins
Happy to be able to help!
If you could, please mark the thread as answered, so others with similar problems can find a solution through the forums more efficiently.
Jim
