MODEL BUILDER: CREATING NEW FOLDER IN MODEL PREVENTS REST OF MODEL FROM RUNNING
7414
09-23-2013 10:25 AM
EricPiza
Hello everyone,
I want to create a model in which 1) a new folder is created on the C drive and 2) various new layers are created and saved into this folder. When I create the model and run it in the edit window (via "validate entire model" and then "run") everything works fine. However, when I attempt to the run the model directly from Arctoolbox (by double clicking the model name) the model doesn't run. I get an error message stating that the new folder doesn't exist...thus there is no where to save the layers to.
Is there a way around this? Specifically, can I force the model to run even though the folders are not present at the outset (since the first thing the model does is create these necessary folders)?
Thank you,
AkosKisreti1
Could you share your model or specify what it is doing?
I tried but I was not able to reproduce your problem.
Akos
EricPiza
Hello Akos,
I have attached the model as well as the shapefile it refrences.
Thank for your help!
AkosKisreti1
Hi Eric,
I have made one modification to your model and it is worked for me:
At the end of your model you added the output folder again, which doesn't exist when the Model runs. But if you use the output of the Create Folder tool (RTMDX_POLYTOPOINTS_IN) as an input for Create Random Points tool, it is working.
I attached the model.
I hope you get the results you wanted.
Best,
Akos
EricPiza
Hello Akos,
That worked for me...thanks for your help!
