Legend layout production
1856
06-02-2017 08:19 AM
DiogoSilva1
Hey there,
I am seeking for an information regarding legend layout production.
Currently, I've some maps divided into different dataframes with the same base-legend, which allows me to compare different data from different times.
I pretend to make the map legend cleaner - currently it looks like THIS - and I want to add less numbers in each class - like HERE. Anyone knows how can I make a legend like THIS in ArcGIS 10.4.1?
I cannot find any legend example in ArcGIS 10.4.1. that suits what I want.
Thank-you in advance for those ones who may answer
Kind regards,
DanPatterson_Retired
right-click on the legend, convert to graphics, split it into its constituent parts, edit as you see fit, then regroup and revert as needed... it is a manual method since there is no automatic method
DiogoSilva1
Hey there @Dan Patterson ,
Thank-you a lot for your answer.
It is know working as I wanted
