Keyboard shortcut - create points
3896
10
04-30-2020 11:23 AM
ScottSweet
Is there a keyboard shortcut for creating points?  I can't find one anywhere in the documentation.  This seems like it would be the easiest shortcut to implement ever.  Do I really have to use a different GIS software to avoid thousands of mouse clicks?
DanPatterson_Retired
If you have a laptop with a touchpad, you can simply use the mouse to point, then hit the touch pad to add the point.
And you can switch up fingers on the touchpad to lessen the load
