How to Change Layout Task in Model Builder?
3368
03-24-2011 08:45 AM
Stefan_Arndt
when i create a schematic diagram with the model builder, is it possible to change the layout task?
From "Geo - Initial Positions" to "Smart Diagram" inside the model?
The normal way with ArcGIS Dekstop is easy to handle, but i didn`t found a solution for a geoprocessing service / model builder, which is used on a arcgis server ....
can you help me?
best regards,
Stefan
RickAnderson
Not from the model, but that is built into the diagram template definition.  The concept of generate diagram is disconnect from the definition of what diagram type or template you want to generate against.  When you configure your schematic dataset, you create a template (version 10), or a diagram type (pre-10).  At that level of configuration you can specify a particular layout algorithm to be the default for that template.  Then anyone generating a diagram (from engine, server, desktop, GP etc...) using that template will automatically get that layout applied.
Stefan_Arndt
Yip, this works! Thank you very much!
