Help, Interpolation?????
759
01-15-2014 07:45 AM
thanhnguyen_tien
Dear everyone,
I have the following problem: I need to calculate an average precipitation amount on a catchment using an IDW and Kriggiing interpolation. The interpolation is performed in a loop since each precipitation station contains several years of daily measurements (10000 and more interpolations). I have managed to solve this problem by overwriting precipitation value in attribute table of the station shapefile using
My database is described as look like:
Sheet1 is look like: column1 column2  column3 column4 column5
id       name      lat        lon    elevation
1      station1   20.1   106.5    34
2       station2   20.3    106.8     13
n       stationN.....
Sheet2 is look like: column1 .... columnN
date          station1   station2  station3 ....stationN
1/1/1981        0           0.1        0.3      ....      0.5
31/12/2000    0.9        1.2         2.4       ... .   1.4
Thank you very much indeed.
Best regards,
