Graphic inserted in templates using program leads to ArcMap Crash if moved with mouse
1857
04-20-2010 02:24 AM
by Anonymous User
Not applicable
Original User: prabusankar_s
Hi ,
I tried creating a graphic (IGroupElement)  in Page Layout using VBA program when i try to move that graphic(element) with mouse it is not moving or it hangs the Arcmap to crash.
But when i use the drawing toolbar available in ArcMap to create the same element and try moving works fine.
Attaching hereby a doc shows what i have done. and also the .MXD.
Somebody have any idea why this program behaves differently, Please let me know.
Thanks in Advance.
Regards
Prabu Sankar
by Anonymous User
Not applicable
Hi all,
The graphic polygon created with IPointcollection interface was not moving when grouped along with another element.
I have written to my regional ESRI support and they send me another work around to create polygon.
The polygon that created with ISegmentcollection Interface would work fine when used a grouped element in arcmap.
Consider this if anybody is facing issue in creating polygon for graphic.
Regards
Prabu Sankar
