Filter records based on the time they were created
907
01-19-2021 01:45 AM
Jon_Tait
Hi. I have a Survey123 used by the public to make complaints about noise from industry. I'm using that data to populate a dashboard so the enforcement officer can assess the results. The officer would like to only see those records created at nighttime (between 23:00 and 07:00). Is there a way to filter the records in the web map to show only those records?
I have a CreationDate filed which includes the time but I don't seem to be able to filter against this, only by the date they were created.
Thank you
Jon
Environmental Control Officer
East Riding of Yorkshire Council, UK
Tags (3)
by Anonymous User
Not applicable
Hi Jon,
A screenshot of your attribute table structure, and your dashboard configuration of this service would help with troubleshooting.
This should be a straight forward filter to apply, so it may require a bit of digging to figure out where the problem is 🙂  It could be that the field you want to filter on isnt the correct field type - id check first that this is a standard date field. Another option is to make this service time enabled, and register that field as a time enabled field.
Let me know how you go 🙂
