Exporting vector field to png/pdf/jpeg: bad representation
4281
8
06-09-2016 01:01 AM
RuiRibeiro1
most of the arrows are under or above others. I've changed the resolution and the size of the arrows but it doesn't work.
What can I do to resolve this problem.
Regards
NeilAyres
Can you show us a picture of what is not correct.
Is this a map you are exporting?
Plus software version etc.
RuiRibeiro1
This is an example: velocities in a river.
I'm using ARCMAP 10.4 and the resolution is 340 dpi and the problem happens in every machine
Changing resolution or size of the map doesn't help.
Only thin that works is to use a very limited density of arrows, but if I use that option I don't have the precision needed.
Regards
NeilAyres
And on the screen it looks fine?
Only when the map is exported does it change to this?
Perhaps experiment with different formats, tried pdf?
RuiRibeiro1
On screen there is no problem. The arrows are well drawn.
When I export, this problem happens. No matter the format I try to export, this always happens. In my previous version of 10.2 it happened too. Also if I try to print instead of export: same problem.
NeilAyres
As a work around, you could just screen grab your map layout and use that instead.
RuiRibeiro1
Well, that way I can't have the right scale or file resolution so that isn't an option.
Thank you nonetheless
NeilAyres
Well scale is relative . Is this layout going straight to paper at a fixed size? If its not, then the scalebar is all you need.
I thought it wasn't, because you were out putting an image for dropping into a report or something.
My laptop screen has enough resolution to look fine in powerpoint or a word doc. Just quicker that way.
NeilAyres
And very cool data there Rui...
