Exporting map to pdf (ArcMap 10.3)
36184
27
12-22-2014 02:22 AM
LutzVogel1
Hey Community,
after the installation from ArcMap 10.3 the option export map to pdf does not work (properly) anymore. Even with the smallest test project the printed pdf document has missing text, labels, legend, .... Have you faced the same problems. Exporting to jpg, tiff, png works fine.
Merry Christmas
Lutz
XanderBakker
Esri Esteemed Contributor
Hi Silvia, you are responding to a  thread that is a year old. You may get more answers if you post your question as a new question in the Python​ space.
Although we could provide a complete script that exports your map, you may benefit more if you would learn a bit more about Python. You will need the mapping module:Introduction to arcpy.mapping—Help | ArcGIS for Desktop
and this tutorial contains a section that shows how you can export a map to PDF: Getting started with arcpy.mapping tutorial—Help | ArcGIS for Desktop
However, you may want to start with these topics:
What is Python?—Help | ArcGIS for Desktop
What is the Python window?—Help | ArcGIS for Desktop
What is ArcPy?—Help | ArcGIS for Desktop
AnnaVetter1
This patch resolves the issue for all users working in a locale with non-US decimal separators. ArcGIS 10.3 (Desktop, Engine, Server) PDF Export for non-US decimal separators Patch | Samples and U...
NicolasELIE
It works. Thanks a lot.  ^^
RijuStephen
I am using 10.2
NicolasELIE
Hi. i can't see you pict. But wen i was in 10.2, i have not problems.
AlejandraEpiscopo1
It works in Spanish.
StaffanstorpsKommun
This patch does not solve the problem in Sweden
IngridRuthy
Hi
I have the same problem. But this patch doesn't work with ArcGIS 10.3.1.
Have you the same issue ?
