Exporting Data Driven Pages to EPS using Python
6325
12
10-20-2010 02:18 PM
TomFlahive
Currently in ArcGIS 10 you can export all of the pages of a data driven pages map book to .pdf format.  Unfortunately, you cannot do the same thing when exporting to .eps format or any of the other export formats (not sure why).  Is there a way to us python to iterate through the individual pages of a data driven pages map book so that each page can be exported to .eps one by one?
malcolmgreer
I have this running but wondering if anyone has it running for selected pages ?
@Kay:  He's referring to the option to set jpeg quality when scripting the export in Python.  My colleagues have had success running this one, with no negative image results:
mxd = arcpy.mapping.MapDocument("CURRENT")
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
  mxd.dataDrivenPages.currentPageID = pageNum
  arcpy.mapping.ExportToEPS(mxd, r"C:\Temp\Map_Page" + str(pageNum) + ".eps", image_quality="BETTER", image_compression="DEFLATE", picture_symbol="RASTERIZE_PICTURE", convert_markers=True, embed_fonts=False, jpeg_compression_quality=1)
del mxd
However, when I run the ExportToEPS code with the "jpeg_compression_quality=1" option, I get the following error message:
Runtime error <type 'exceptions.TypeError'>: ExportToEPS() got an unexpected keyword argument 'jpeg_compression_quality'
My colleagues are running Adobe Acrobat Standard 8 and I am running Adobe Acrobat Standard 9, so that may be where the disparity lies.  I modified the script to be built into a tool with output variables, and omitted the "jpeg_compression_quality" option and it works very well for me (no negative images):
# Import ArcPy site-package and os modules
import arcpy
import os
# Set the output workspace
outWorkspace = arcpy.GetParameterAsText(0)
# Set the output map name
mapname = arcpy.GetParameterAsText(1)
# Tell ArcMap to use the current MXD
# Execute dataDrivenPages
  arcpy.mapping.ExportToEPS(mxd, outWorkspace + str(mapname) + str(pageNum) + ".eps", image_quality="BETTER", image_compression="DEFLATE", picture_symbol="RASTERIZE_PICTURE", convert_markers=True)
del mxd
Search on "ExportToEPS" in ArcGIS 10 Help to get the breakdown of the syntax and all output options.  You'll notice that the "jpeg_compression_quality" option is not mentioned in there...
JeffBarrette
At 10.0 you will have to manage the selection yourself.  You will need to run a loop on your rows, create a list of pagenames or numbers and step through each DDP page using that list.  Similar to the help sample provided in this thread.
At 10.1, we added a DDP.selectedPages property that will return a list of index numbers automatically.
Jeff
malcolmgreer
Thanks Jeff,
What I am doing now is just selecting the pages from the attribute table I have and then exporting them as pdfs. Then I use the reduce pdf size utlity in adobe once I have all my maps exported.
Guess this will work for now...
