End point circular arc from table
1305
05-29-2020 11:22 AM
LisaMerkhofer1
I would like to create a polygon feature class of arc shapes using a table of values. I have values for starting point, end point, and radius which I can manually enter by clicking the points and entering the radius in the "Circular Arc" parameter dialog box. Is there a way I can create a series of arcs using a table of these values instead?
Tags (1)
DanPatterson
MVP Esteemed Contributor
You have the procedure for sure
Create circular arcs—ArcGIS Pro | Documentation
There is nothing on the Code Sharing site either
ArcGIS Code Sharing
... sort of retired...
