DDP export to rasters with page names?
3321
07-20-2012 12:14 PM
JohnSobetzer
Honored Contributor
I have been using an arcpy script to export a view to a georeferenced tif, but the tifs come out as XXX1.tif, XXX2.tif, etc. where XXX is whatever text I put in the path and the number is the pageNum from the index file.  I'm probably missing something incredibly obvious but I can't find a way to have the output tifs include their individual DDP page names as happens with the standard export to pdf in a DDP.  Any suggestions?
If it makes it any easier here is the entire script which produces a series of tifs (and tfws) starting with currentName1.tif and ending at currentName19 in one particular case.
import arcpy
... mxd = arcpy.mapping.MapDocument("Current")
... df = arcpy.mapping.ListDataFrames(mxd)[0]
... ar = df.extent.height / df.extent.width
... for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
...     mxd.dataDrivenPages.currentPageID = pageNum
...     print "Exporting page {0} of {1}".format(str(mxd.dataDrivenPages.currentPageID), str(mxd.dataDrivenPages.pageCount))
...     arcpy.mapping.ExportToTIFF(mxd,r"C:\Project\currentName" + str(pageNum) + ".tif",df,9306,9306*ar,300,True)
... del mxd
JeffBarrette
Have you tried something like:
>>>  mxd = arcpy.mapping.MapDocument("Current") ddp = mxd.dataDrivenPages df = arcpy.mapping.ListDataFrames(mxd)[0] for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):     mxd.dataDrivenPages.currentPageID = pageNum     arcpy.mapping.ExportToTIFF(mxd,r"C:\Temp\\" + str(ddp.pageRow.Name) + ".tif", df)
Where the "Name" pageRow.Name is the name of the field in the index layer.
Jeff
JeffBarrette
Jeff
JohnSobetzer
Honored Contributor
Thank you very much Jeff.  It's just what I needed.
I figured it had to be simple but I don't know python beyond mixing samples I can find. This one stumped me and I found a workaround right after posting so I let it go.  The workaround, however, is a clumsy one to set up (it uses a batch file renamer and a text file with input and output names) so this is so much better.
This is my current script to produce a properly georeferenced set of tifs from the same project I use for pdfs, showing a generic path of C:\Project for the output.
import arcpy
... ddp = mxd.dataDrivenPages
...     arcpy.mapping.ExportToTIFF(mxd,r"C:\Project\ctype12_" + str(ddp.pageRow.Name) + ".tif",df,9306,9306*ar,300,True)
... del mxd
George_ChandeepCorea
Thank you for this. It works perfectly and is exactly what I needed!
ChristopherDean
Jeff
This works great for letting me name my files as I need to but it doesn't export the entire layout view of the mxd. Any idea what code is needed to export the layout view?
Chris
ChristopherDean
Found the answer in this thread:
http://forums.arcgis.com/threads/80836-exporting-layout-view-in-arcpy
replaced df with data_frame = "PAGE_LAYOUT"  and then df with data_frame and it exported the layout view correctly.
Chris
