Custom coordinate systems - Longitudinal ranges
2265
03-17-2017 10:29 AM
ChristineHomuth
I'm using the SimpleCylindrical_Titan coordinate system, which has a range of 180W to 180E.
Data for Titan (Saturn's moon) typically ranges from 0 to 360W, centering on 180.
Is there any way to alter the range of values in order to display properly from 0 to 360, rather than 180 to 180?
Thank you,
Christine
JimCousins
Interesting question. I am assuming you wish to create this coordinate system for use in ArcGIS, so I am adding  Melita Kennedy as a keyword here, as she will see it since it references her. She is Senior Product Engineer for Map Projections and Transformations at ESRI, and your best bet for a solution.
Best Regards,
Jim
ChristineHomuth
Hi Jim and Melita,
Yes, I was trying to create a custom coordinate system. I'm able to change the central meridian (180), but not the range (0 to 360, positive west).
The coordinate system is based on SimpleCylindrical_Titan, with the following ranges and radii:
  CenterLongitude    = 180.0
  EquatorialRadius   = 2575000.0 <meters>
  PolarRadius        = 2575000.0 <meters>
  LongitudeDirection = PositiveWest
  LongitudeDomain    = 360
  MinimumLatitude    = -90.0
  MaximumLatitude    = 90.0
  MinimumLongitude   = 0.0
  MaximumLongitude   = 360.0
Christine
JimCousins
out of curiosity, what happens if you set the CenterLongitude = 0.0 ?
MelitaKennedy
Esri Notable Contributor
I don't know that we can do anything directly. I think it will be easier to re-georeference the data. Note the "postiveWest" for the LongitudeDirection value. You could just force the raster into 0-360 latitude/longitude that way. Or possibly georeference into a simple cylindrical system, center at 180.
Melita
ChristineHomuth
Ok, thank you Melita!
