Create sequential numbers
1159
02-05-2020 12:32 PM
ChrisSlinko
I would like to create sequential numbers automatically without the use of the field calculator.  I have a point feature class with a column that has sequential numbers when I go to add a point I would like it to calculate or add  the next number in the sequence. I would like to do this without using python or field calculator.  Any help would be appreciated.  Thank you in advanced.
JoeBorgione
I know of two approaches:
Attribute Assistant-  Attribute Assistant | ArcGIS Solutions
and
Attribute Rules  Introduction to attribute rules—Geodatabases | Documentation
The former is somewhat dated while the latter is here for the long haul.
