Convert DateTime field to Date in Label Expression
5489
10-30-2014 08:32 AM
mpboyle
Honored Contributor
I have a DateTime field (ex: CreatedDate) and would like to only show the date with the label. How would I setup the label expression to do this using python?
Thanks in advance!
Tags (1)
Marco_AlejandroBonilla
mpboyle
Honored Contributor
Hmmm...I tried for way too long to use python.  Switched to VBScript parser and got what I wanted in a few minutes using FormatDateTime([field],2)...like what is shown in the idea above.
Thanks for the response!
MarkCederholm
You cannot use VBScript expressions if you are publishing to ArcGIS Server.  I ran into this problem, and the key to understanding it is found in the first sentence of the third paragraph of the "Building label expressions" help topic:
"Field values are automatically cast to text strings."
Nonetheless, Python expressions are awkward for parsing strings because you can't use square brackets .  For example, in the following expression:
[DATEFIELD].split(" ")[0]
the parser will look for a field called "0" and fail.  Instead, you can use the following:
[DATEFIELD].split(" ").pop(0)
If a field is nullable, then you need to be prepared to handle a null value:
def FindLabel ([DATEFIELD]):
    s = [DATEFIELD]
    if s is None:
        return None
    return s.split(" ").pop(0)
Of course, label performance is adversely affected by using a function, which in turn affects the return time on an ArcGIS Server map service.
[BTW, if you look at the examples, the most appropriate ones for parsing strings are in JScript, and that is probably the better route to take.]
WesMiller
This article ArcGIS Desktop explains date fields it may help. I was able to use below to pull the date.
def FindLabel ( [LASTUPDATE] ):
  d = [LASTUPDATE]
  a = d.split(" ")
  return a[0]
