Clickable images in map journal - change main content
4244
01-13-2015 10:40 AM
MatthewMcBride
Is it possible or could it be possible to make imaged clickable in the sidebar similar to text to change main frame content. Right now you can do it if you change it in source but it only works if you use the image-container activate-fullscreen within your div. Is there a way to make images clickable without having the fullscreen option activated? They don't seem to be clickable without it.
