Change "base point" for polygon snapping
5134
02-25-2016 05:20 PM
forestknutsen1
How do I change the "base point" (the small x) for a polygon when I am moving it?
AdrianWelsh
MVP Honored Contributor
You can turn on midpoint snapping from the Snapping toolbar. To do this, start an edit session, and in the Edit Toolbar, drop down the Editor list, go to Snapping and then Snapping Toolbar. In the snapping toolbar, you can select midpoint snapping.
Now, to move the anchor point, base point, there are some steps listed here:
34874 - Move the anchor point of a feature
  1. Start an Edit Session.
  2. Select the Edit tool and double-click the feature.
  3. Select the Rotate tool on the Editor Toolbar.
  4. Hover the mouse over the feature's anchor to move it to a new location.
  5. Click and drag the anchor point to a new location.
Then you can drag the anchor point to the mid section of that line segment.
DanPatterson_Retired
The base point is the first/last point created during the process of digitizing/creation if memory serves.  You might want to run an experiment
AdrianWelsh
forestknutsen1
Great! Thanks Dan and Adrian.
JamalNUMAN
Legendary Contributor
In Pro, the anchor point is indicated by yellow point. The same approach can be used to move the anchor point (ctrl + hover over then drag and drop)
Jamal Numan
