Can you symbolize a polygon feature based on an attribute value instead of color fill
2461
10-26-2020 12:54 PM
TinaKwitkoski
I am wondering if you can symbolize a poly feature based on a text value in the attribute table instead of the normal colorfills.  Does anyone know? I want the polygon to be letters ie L,M,H based on the value in the table. I Know I could drop the poly to a centroid and do it that way and change to a character symbol, but I would rather not..
Thanks.
Tina
arcgis arcmap #symbology issues
DavidPike
MVP Notable Contributor
Go to properties of the layer, then symbology. (I have a text field from a shapefile with A,B,C,D as values - feature class is the same process).
categories - unique values
click 'add all values' near the bottom left, this will add the set of values within that field
OK that
