Campus Map Template - different than Community Maps?
1051
07-22-2011 01:11 PM
AllenRisley
I have signed up to create a campus basemap for the university I work at, so I downloaded the Community Maps Template and the Campus Map Template.  I'm finding the two to be very different.  Is there any documentation aimed specifically at the Campus Map Template?
Allen Risley
Research Analyst
California State University San Marcos
TamaraGrant
Hello Rizbee,
Thank you for your question. When you download the Campus Basemap Template, there should be a "Getting_Started_Campus_Basemap_Template" PDF document. This serves as an outline for the template. If you need more information, you can post your question on the Mapping Center Forum, located here: http://forums.arcgis.com/forums/38-Map-Templates. I'm sure that they would be happy to assist you. Also, some of the same methodology may be able to be used that is currently used for the Community Maps Template. I'm not sure if you are working with ArcGIS 9.3.1 or ArcGIS 10.0, but I have provided links below to our Help system for both versions.
ArcGIS 9.3.1-
http://help.arcgis.com/en/communitymaps/9.3/help/index.html
ArcGIS 10.0-
http://help.arcgis.com/en/communitymaps/10.0/help/index.html
I hope this helps!
Thank you,
Tamara Yoder
Tamara Yoder, Geospatial Analyst
Esri, 380 New York Street, Redlands, CA 92373, USA
T 909-793-2853, ext. 5028, [email protected], esri.com
