batch export jpeg with world files data driven pages
10535
16
06-16-2016 06:41 AM
AntoninGosset
Hi there,
I'd like to know if it is possible to batch export jpg + world file (jpw or so) in batch using a Data Driven Pages python script.
I don't think it is possible because there is a limitation in Arcgis : the layout view doesn't permit the world file attachement and Data Driven Pages only exports layout views.
World file creation is only allowed in Data view.
I don't know if there is a trick / solution to do what I want to achieve using an advanced python script. A script that would run data driven pages in Layout View to export each view as JPG+ world file ?
Example of python script to export Data driven pages as EMF in Data view
mxd = arcpy.mapping.MapDocument("CURRENT")
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
  mxd.dataDrivenPages.currentPageID = pageNum
  arcpy.mapping.ExportToEMF(mxd, r"J:\81B\____Répertoires Trafic\60-Contributions_autres_agences\62-Production\Paris\16_RFF_SCH_SECTEUR\3_production\A_SIG_SchSect\PRODCARTO\11_Prospective\Carte_" + str(pageNum) + ".emf", convert_markers=True)
  del mxd
AntoninGosset
# Iterate map series pages
   a = mxd.dataDrivenPages.pageNameField.name
print(a)
b = r "C:\Export" + "\\" + str(mxd.dataDrivenPages.pageRow.getValue(a)) + ".jpg"
print(b)
arcpy.mapping.ExportToJPEG(mxd, b, resolution=150, world_file=True)
AntoninGosset
Parsing error SyntaxError: invalid syntax (line 7)
DanPatterson_Retired
Did you scrunch all this together to save space?
and what did this print?
print(a)
AntoninGosset
I just tried to make it work but apparently it didn't. I don't know programming so I don't know what I'm doing.
FC_Basson
Then start here: What is ArcPy?—Help | ArcGIS for Desktop
ArcPy/Python is an incredibly powerfull tool.  If you need to do this in the future again, do yourself a favour and learn Python.
FC_Basson
There's a space after the r before the pathname - not allowed.
DavidBarnes
I'm not adept at python, but I think what you'd need to do is somehow cycle through each index feature in data view, zoom to the index feature, export the data view, then repeat with the next index feature, and so on.
