Arcpy exporting PDF problems
3789
10-05-2012 08:55 AM
qiangxue
I will appreciate if you can take a look at my question. I used arcpy.ExportToPDF for my map. It worded well before I upgraded to 10.1. I have attributes table added on the map. Now those tables become very small when I use my python scripts to export PDF. I still can use export to PDF from menu to get the right size of tables on my map. However, python scripts works faster, so I still prefer to using it. Could you find out what reason to make those added attributes tables very small? Thanks a lot.
JeffBarrette
This is a known limit (NIM063441) when exporting "Added Tables" in a layout to PDF from a stand-alone script or script tool.  If you run the same python script from the Python window, using current or a file path to the mxd, it will work.  There is also a known limit trying to export OLE tables.
Here are some Python solutions to working with dynamic tables in a layout using arcpy.mapping.
Static Graphic Tables:
http://www.arcgis.com/home/item.html?id=af4fe32a93554eadbd3be3b0e55326be
Dynamic Graphic Tables:
http://www.arcgis.com/home/item.html?id=3a525b986b774a3f9cbbd8daf2435852
Jeff
JeffBarrette
Could you provide screen shots and anything else that may be unique about your tables (e.g., source data, ole object, etc).
Jeff
qiangxue
see attachments, please.
JeffBarrette
Jeff
