Arc10 - Data Driven Pages not centered
5858
16
09-13-2010 07:28 AM
RobBurnard
I have a series of irregular shapes (polygons) that I'm using as a basis for data driven pages.  Each page has a scale and rotation defined.
My problem is that the irregular shapes do not center in the layout.
If I draw a square it centers just fine but if I modify the square and turn it into a triangle (for example) and then refresh the data driven pages it is no longer centered.
Any ideas?
Thank you,
Rob Burnard
City of London
Canada
JeffBarrette
We reproduced this issue an will hopefully be able to address it in the next service pack.
If you want to check its status, it is: NIM067167
JustinRichardson
We're also having the same problem.  I can't publish the new taxmaps until I find some work around.  Anyone have a temporary fix?
abejohn
Any resolution to this issue yet?
JeffBarrette
This issue will be addressed for SP3 - which is targeted for Oct.
Jeff
JenniferBorlick
I'm on SP3 and having this issue. I made these maps before when I was using an XP machine and was able to get them to work. On Winsows 7 now and they are off center.
JeffBarrette
This issue was addressed for SP3 and verified.  If you are having an issue, it could be a new one.  Please contact Support Services and open an incident.
Jeff
JenniferBorlick
Jeff
User error. I had a sliver of a polygon out of place. Thanks, though.
